주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Teddy Ruxpin Motherboard Replacement
필요한 것
    1. Teddy Ruxpin Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Teddy Ruxpin Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Remove the vest covering the back of the bear.
      • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
      • Captured screws will stay in place, no need to worry about losing this one!
      댓글 쓰기
    2. Teddy Ruxpin Motherboard Replacement: 2 단계, 이미지 1개 중 1개
      • Pull the tab outward to remove the protective plate for the batteries.
      댓글 쓰기
    3. Teddy Ruxpin Motherboard Replacement: 3 단계, 이미지 1개 중 1개
      • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
      댓글 쓰기
    1. Teddy Ruxpin Motherboard Replacement, Arms: 4 단계, 이미지 3개 중 1개 Teddy Ruxpin Motherboard Replacement, Arms: 4 단계, 이미지 3개 중 2개 Teddy Ruxpin Motherboard Replacement, Arms: 4 단계, 이미지 3개 중 3개
      • Cut the orange shirt and zip tie.
      • Remove the zip tie.
      댓글 쓰기
    2. Teddy Ruxpin Motherboard Replacement: 5 단계, 이미지 1개 중 1개
      • Cut across the back seam of the head of the bear along the arrow.
      • This damages the bear's exterior and will require resewing.
      댓글 쓰기
    3. Teddy Ruxpin Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Teddy Ruxpin Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Teddy Ruxpin Motherboard Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the interior of the doll.
      • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
      • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
      댓글 쓰기
    4. Teddy Ruxpin Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Teddy Ruxpin Motherboard Replacement: 7 단계, 이미지 2개 중 2개
      • Extract each arm button.
      • Pull on the stuffing of the bear and not the wire to remove the arm button.
      댓글 쓰기
    5. Teddy Ruxpin Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Teddy Ruxpin Motherboard Replacement: 8 단계, 이미지 2개 중 2개
      • Pull off the rest of the outside layer of the bear.
      댓글 쓰기
    6. Teddy Ruxpin Motherboard Replacement: 9 단계, 이미지 1개 중 1개
      • Unplug the arms from the main body.
      댓글 쓰기
    1. Teddy Ruxpin Motherboard Replacement, Housing Cover: 10 단계, 이미지 3개 중 1개 Teddy Ruxpin Motherboard Replacement, Housing Cover: 10 단계, 이미지 3개 중 2개 Teddy Ruxpin Motherboard Replacement, Housing Cover: 10 단계, 이미지 3개 중 3개
      • Unscrew the eleven circled 12.5mm Phillips #1 screws.
      • Remove the top of the housing to access the electronics inside.
      댓글 쓰기
    1. Teddy Ruxpin Motherboard Replacement, Eyes: 11 단계, 이미지 1개 중 1개
      • Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
      댓글 쓰기
    2. Teddy Ruxpin Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Teddy Ruxpin Motherboard Replacement: 12 단계, 이미지 2개 중 2개
      • Unplug the two sets of wires connected to the back of the eyes by using moderate to high force.
      댓글 쓰기
    3. Teddy Ruxpin Motherboard Replacement: 13 단계, 이미지 1개 중 1개
      • Once those wires are disconnected, desolder the wires connected from the eye motherboard.
      댓글 쓰기
    1. Teddy Ruxpin Motherboard Replacement, Mouth: 14 단계, 이미지 2개 중 1개 Teddy Ruxpin Motherboard Replacement, Mouth: 14 단계, 이미지 2개 중 2개
      • Remove five 12.5mm Phillips #1 screws.
      • Pull the mouth mechanism out of the shell.
      댓글 쓰기
    2. Teddy Ruxpin Motherboard Replacement: 15 단계, 이미지 2개 중 1개 Teddy Ruxpin Motherboard Replacement: 15 단계, 이미지 2개 중 2개
      • Unscrew the last 12.5mm Phillips #1 screw holding the mouth together
      • Open the mouth mechanism
      댓글 쓰기
    1. Teddy Ruxpin Motherboard Replacement, Motherboard: 16 단계, 이미지 1개 중 1개
      • Remove the two 12.5 MM Phillips #1 screws holding the main motherboard into place.
      댓글 쓰기
    2. Teddy Ruxpin Motherboard Replacement: 17 단계, 이미지 1개 중 1개
      • Desolder all connections.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Jayin Patel
회원 가입일: 01/23/20
406 평판
안내서 4개를 작성함
Cal Poly, Team S18-G5, White Winter 2020 Cal Poly, Team S18-G5, White Winter 2020 회원
CPSU-WHITE-W20S18G5
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 27
전체 시간: 2,222
