주요 콘텐츠로 건너뛰기
Tektro Aires Disc Brakes Brake Pad Replacement
Randall Eakes
Randall Eakes6 다른 기여자
최종 수정일 April 9, 2024
20 - 40 분
조정
더 나은 이미지가 필요함
더 많은 이미지가 필요함
This guide is to replace your Tektro Aires Disc Brakes pad, the guide will show you step by step with instructions and pictures. you may need to replace your brake pads due to wear or damage. In order to complete the replacement you will need to use the tools mentioned (1x5 mm Hex Key, 1 x Large needle nose pliers) on the steps that they're needed for. It is recommended to wear gloves as skin oils will affect the break pad's performance.(If not be careful not to touch the break pads when reinstalling)
  1. Tektro Aires Disc Brakes Brake Pad Replacement, Brake Pad: 1 단계, 이미지 1개 중 1개
    • Bend the retention pins straight using a pair of needle nose pliers.
  2. Tektro Aires Disc Brakes Brake Pad Replacement: 2 단계, 이미지 2개 중 1개 Tektro Aires Disc Brakes Brake Pad Replacement: 2 단계, 이미지 2개 중 2개
    • Loosen the two mounting bolts using a 5mm Hex Key.
    • Different bike models will have the mounting points in different locations.
  3. Tektro Aires Disc Brakes Brake Pad Replacement: 3 단계, 이미지 1개 중 1개
    • After removing the bolts pull of the brake caliper from the brake disc.
  4. Tektro Aires Disc Brakes Brake Pad Replacement: 4 단계, 이미지 1개 중 1개
    • Using the needle nose pliers remove the retention pin by pulling on it.
  5. Tektro Aires Disc Brakes Brake Pad Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the brake pads by pulling on them and realesing them from the caliper.
  6. Tektro Aires Disc Brakes Brake Pad Replacement: 6 단계, 이미지 1개 중 1개
    • Place the spring on the new Tektro Disc Brake Pad as shown.
    • The other brake pad will go on the spring opposite the first brake pad.
결론
  • The steps for the front wheel are the same as the back wheel.
  • Follow steps in reverse for reassembly.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Randall Eakes
회원 가입일: 10/26/21
193 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 73
지난 30일: 194
전체 시간: 5,689
