주요 콘텐츠로 건너뛰기
Texas Instruments TI-5130 Power Cord Replacement
Shannon Perkins
Shannon Perkins다른 한 명의 기여자
최종 수정일 January 6, 2016
15 - 45 분
어려움
Power cords can become damaged due to pinching or cutting of the cord. Follow this guide to replace the power cord.
필요한 것
부품
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Texas Instruments TI-5130 Power Cord Replacement, Power Cord: 1 단계, 이미지 2개 중 1개 Texas Instruments TI-5130 Power Cord Replacement, Power Cord: 1 단계, 이미지 2개 중 2개
    • Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
  2. Texas Instruments TI-5130 Power Cord Replacement: 2 단계, 이미지 2개 중 1개 Texas Instruments TI-5130 Power Cord Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the top cover.
    • Gently pull up on the power cord to remove it from the back cover.
  3. Texas Instruments TI-5130 Power Cord Replacement: 3 단계, 이미지 2개 중 1개 Texas Instruments TI-5130 Power Cord Replacement: 3 단계, 이미지 2개 중 2개
    • This step is optional; however it makes it easier to work.
    • Using a PH1 screwdriver remove the two 10mm screws that hold down the transformer.
    • Gently remove the transformer.
    • Make sure that the calculator is not plugged in.
  4. Texas Instruments TI-5130 Power Cord Replacement: 4 단계, 이미지 2개 중 1개 Texas Instruments TI-5130 Power Cord Replacement: 4 단계, 이미지 2개 중 2개
    • Use a wire cutter to cut off the white cap and expose the wires. Try to cut close to the tip of the white cap - to leave as much wire as possible.
    • Note that there are 2 sets of wires connected to the power cord. Do each set of wires separately.
  5. Texas Instruments TI-5130 Power Cord Replacement: 5 단계, 이미지 2개 중 1개 Texas Instruments TI-5130 Power Cord Replacement: 5 단계, 이미지 2개 중 2개
    • Use a wire stripper to remove 1/2” of the protective covering on each of the wires.
  6. Texas Instruments TI-5130 Power Cord Replacement: 6 단계, 이미지 2개 중 1개 Texas Instruments TI-5130 Power Cord Replacement: 6 단계, 이미지 2개 중 2개
    • Twist the exposed section of the 2 wires together.
    • Twist a new cap over the exposed wires. Make sure that the cap covers all of the exposed wire.
    • Repeat steps 4-6 for the second set of wires.
  7. Texas Instruments TI-5130 Power Cord Replacement: 7 단계, 이미지 1개 중 1개
    • Replace the transformer and ensure that the new wire caps fit in the space shown.
    • Plug in the new power cord and test the calculator before replacing the top cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Shannon Perkins
회원 가입일: 09/17/15
652 평판
안내서 3개를 작성함
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 회원
USFSM-STEWART-F15S1G2
5 회원들
안내서 20개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 10
전체 시간: 560
