주요 콘텐츠로 건너뛰기
Texas Instruments TI-5130 Printer Unit  Replacement
Shannon Perkins
Shannon Perkins다른 한 명의 기여자
최종 수정일 January 25, 2016
5 - 10 분
조정
Follow this guide to remove and replace the printing unit in the TI-5130 electronic calculator.
필요한 것
부품
도구
  1. Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: 1 단계, 이미지 2개 중 1개 Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: 1 단계, 이미지 2개 중 2개
    • Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
  2. Texas Instruments TI-5130 Printer Unit  Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the calculator back over and remove the top cover.
  3. Texas Instruments TI-5130 Printer Unit  Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the printing unit from the motherboard by pulling up on the connector – located in the bottom left of the motherboard.
  4. Texas Instruments TI-5130 Printer Unit  Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the ink cartridge by pushing the tab back then lifting it out to gain access to the screw that holds the printer in place.
  5. Texas Instruments TI-5130 Printer Unit  Replacement: 5 단계, 이미지 2개 중 1개 Texas Instruments TI-5130 Printer Unit  Replacement: 5 단계, 이미지 2개 중 2개
    • Using a PH1 screwdriver remove the 10mm screw that holds down the printer unit.
    • Remove the printer unit by lifting it up.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Shannon Perkins
회원 가입일: 09/17/15
652 평판
안내서 3개를 작성함
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 회원
USFSM-STEWART-F15S1G2
5 회원들
안내서 20개를 작성함
댓글 2개
wehre did you buy the replacement printer
Tino ullrich - 답글
what sources are there for TI-5130 printer unit?
Norman Todd - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 13
지난 30일: 38
전체 시간: 2,503
