주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Claw Music Player Cleaning
필요한 것
    1. The Claw Music Player Cleaning, Bottom Cover: 1 단계, 이미지 1개 중 1개
      • Place The Claw in upright position with controls facing you.
      댓글 쓰기
    2. The Claw Music Player Cleaning: 2 단계, 이미지 1개 중 1개
      • Gently flip The Claw machine upside down with the controls facing you.
      댓글 쓰기
    3. The Claw Music Player Cleaning: 3 단계, 이미지 1개 중 1개
      • Remove all ten screws from the bottom cover using a Phillips #1 screwdriver.
      • You will need a screwdriver with a long thin neck to fit in the screw holes.
      댓글 쓰기
    4. The Claw Music Player Cleaning: 4 단계, 이미지 2개 중 1개 The Claw Music Player Cleaning: 4 단계, 이미지 2개 중 2개
      • Slide the bottom cover off to the side.
      • Do not completely remove bottom cover as it is still connected to wires.
      댓글 쓰기
    5. The Claw Music Player Cleaning: 5 단계, 이미지 1개 중 1개
      • Complete removal of the bottom cover is not necessary, however if you feel you need to take the cover completely off the machine to complete your task it can be done by the following process.
      • You will need to cut the two green wires attached to the music player.
      • Then you will need to cut the white wire that leads to the battery compartment.
      • Finally you will need to cut the black wire leading to the battery compartment as well.
      • The complete removal of the bottom cover requires the cutting and soldering of wires. For help with soldering reference: 연결부 납땜 및 납제거 방법.
      댓글 쓰기
    1. The Claw Music Player Cleaning, The Claw Music Player Cleaning: 6 단계, 이미지 1개 중 1개
      • Once you have removed the bottom cover you should have clear access to the music player.
      • Locate the music player and check to see if it is visibly dirty or clogged.
      • If there is any amount of dust or dirt on the music player it should be cleaned.
      • Using the straw that comes with your air duster, aim the duster in a way that the air will push the dust away from the music player.
      • If cleaning the music player is not enough, you may need to refer to the Music Player Replacement Guide
      댓글 쓰기
    2. The Claw Music Player Cleaning: 7 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • You DO NOT want to force the dust further into the music player by directing the air into the player.
      • If there are any large pieces of lint or dust in the sound port, those can be removed with your precision tweezers.
      • Once you are certain you have removed all of the dust and dirt from the music player you should reassemble the device and test it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alain Pierre
회원 가입일: 03/22/16
1,188 평판
안내서 9개를 작성함
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G8
3 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 38
전체 시간: 1,176
