주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Thread a Sewing Machine
필요한 것
    1. Thread a Sewing Machine, Thread a Sewing Machine: 1 단계, 이미지 3개 중 1개 Thread a Sewing Machine, Thread a Sewing Machine: 1 단계, 이미지 3개 중 2개 Thread a Sewing Machine, Thread a Sewing Machine: 1 단계, 이미지 3개 중 3개
      • Place a spool on the pin. Pull the thread from the spool straight out, following the length of the machine.
      • Hook the thread under the eyelet on the outer edge of the machine.
      • With one hand, hold the spool steady. Using the eyelet as a pivot, pull the string perpendicular with the other hand. Lay the thread into the slot, which bisects the top of the machine.
      댓글 쓰기
    2. Thread a Sewing Machine: 2 단계, 이미지 3개 중 1개 Thread a Sewing Machine: 2 단계, 이미지 3개 중 2개 Thread a Sewing Machine: 2 단계, 이미지 3개 중 3개
      • Pull the thread all the way across the slot on the top of the sewing machine. Then, pull the thread down toward the presser foot.
      • There is a lever just above the presser foot. Hook the thread under the lever until it rests in the crux.
      • Pull the thread back up toward the top of the machine.
      댓글 쓰기
    3. Thread a Sewing Machine: 3 단계, 이미지 3개 중 1개 Thread a Sewing Machine: 3 단계, 이미지 3개 중 2개 Thread a Sewing Machine: 3 단계, 이미지 3개 중 3개
      • At the top of the machine, lead the thread along the groove of the take-up lever.
      • Once you've fed the thread into the crux of the take-up lever, pull the thread back down towards the presser foot.
      • If you've threaded correctly, your thread should form a complete zigzag—first down, then up, then back down all the way to the presser foot.
      댓글 쓰기
    4. Thread a Sewing Machine: 4 단계, 이미지 2개 중 1개 Thread a Sewing Machine: 4 단계, 이미지 2개 중 2개
      • Hook the thread behind the small, bent arm where the needle attaches to the machine.
      • Guide the thread, from front to back, through the eye of the needle, leaving a loose end of approximately 10 cm.
      • If the end of your thread has frayed and you cannot guide it through the eye of the needle, snip off the frayed end and try again.
      댓글 쓰기
    5. Thread a Sewing Machine: 5 단계, 이미지 2개 중 1개 Thread a Sewing Machine: 5 단계, 이미지 2개 중 2개
      • After you've guided the thread through the eye of the needle, pull the thread down and through the large groove in the presser foot.
      • Hook the thread along the groove and pull it perpendicular toward the body of the machine.
      댓글 쓰기
    6. Thread a Sewing Machine: 6 단계, 이미지 3개 중 1개 Thread a Sewing Machine: 6 단계, 이미지 3개 중 2개 Thread a Sewing Machine: 6 단계, 이미지 3개 중 3개
      • While continuing to hold the top thread advance the sewing machine with the balance wheel (also know as the hand wheel), to pick up the bobbin thread.
      • Only turn the balance wheel in the direction that advances the machine. Usually, this means turning the wheel towards you. Turning the wheel in the opposite direction can ruin the tension on the sewing machine, causing it to jam. See your sewing machine manual for instructions specific to your machine.
      • Grasp these two threads between pinched fingers and pull them in unison toward the body of the machine, leaving two to three inch tails.
      댓글 쓰기
    7. Thread a Sewing Machine: 7 단계, 이미지 2개 중 1개 Thread a Sewing Machine: 7 단계, 이미지 2개 중 2개
      • Slide the sewing machine table onto the machine.
      • Hold the sewing machine table so that is lays flush with the sewing machine.
      댓글 쓰기
    8. Thread a Sewing Machine: 8 단계, 이미지 2개 중 1개 Thread a Sewing Machine: 8 단계, 이미지 2개 중 2개
      • Lock the sewing machine table into place by pushing the clamp lever to the right until it engages.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
91,032 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 70,339개를 작성함
1가이드 댓글
How do u thread a sewmor model 202?
Helen jennings - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 66
지난 30일: 325
전체 시간: 64,264
