주요 콘텐츠로 건너뛰기
Toshiba CB35-C3300 Chromebook 2 Display Replacement
Christopher Manley
Christopher Manley3 다른 기여자
최종 수정일 June 16, 2021
25 - 35 분
조정
With this guide, you will be able to safely remove all broken parts of your current display from this computer and be able to replace it with a new display.
The laptop display is responsible for displaying applications, video, etc. for your laptop. It allows your to visually see controls for your laptop and make changes if necessary. They can be damaged if not handled properly and are known to last for 5 to 10 years.
Some signs that you would need to remove your screen is cracked screen, flickering, incorrect lighting, lines running down the laptop screen, screen is blank, or only half of your screen is showing.
Before you remove a cracked display, it’s important to put tape over the display to prevent any injury to yourself.
필요한 것
도구
  1. Toshiba CB35-C3300 Chromebook 2 Display Replacement, Display: 1 단계, 이미지 1개 중 1개
    • Start by opening your Chromebook and orient the computer as shown.
  2. Toshiba CB35-C3300 Chromebook 2 Display Replacement: 2 단계, 이미지 1개 중 1개
    • Using the opening tool, start at one of the two top corners and pull the faceplate away from the display.
    • Use the opening tool to work your way all the way around the frame.
  3. Toshiba CB35-C3300 Chromebook 2 Display Replacement: 3 단계, 이미지 1개 중 1개
    • Using a Jimmy, carefully pop the bottom of the faceplate away from the display.
  4. Toshiba CB35-C3300 Chromebook 2 Display Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the faceplate by pulling away from the keyboard.
  5. Toshiba CB35-C3300 Chromebook 2 Display Replacement: 5 단계, 이미지 1개 중 1개
    • Using an opening tool, start from one of the top corners of the screen and begin to pry it away from the top of the laptop.
    • Make sure that you can keep the foil on the Chromebook.
  6. Toshiba CB35-C3300 Chromebook 2 Display Replacement: 6 단계, 이미지 1개 중 1개
    • Using the Jimmy, remove the sticker holding the wire to this display.
  7. Toshiba CB35-C3300 Chromebook 2 Display Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully remove the ribbon the display and remove the display from the Chromebook.
결론
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 180
