주요 콘텐츠로 건너뛰기
Toshiba Chromebook 2 Charging Port Replacement
Jason Lomsdalen
Jason Lomsdalen3 다른 기여자
최종 수정일 November 9, 2019
6 분
조정
When the charger is plugged in but the Chromebook doesn't begin charging and the outlet the charger is plugged into works, then the charging port needs to be replaced. This is an easy fix that just requires you to pry up a hinge and pull some cables out that connect the port to the motherboard. This part can be purchased and swapped out.
필요한 것
도구
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Toshiba Chromebook 2 Charging Port Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Charging Port Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Charging Port Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Charging Port Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Charging Port Replacement: 4 단계, 이미지 2개 중 2개
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Charging Port Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Charging Port Replacement, Charging Port: 6 단계, 이미지 1개 중 1개
    • The changing port is located on the left side of the computer, when flipped over and the back cover is taken off, the port will be in the top right corner.
    • In order to access the port, the metal hinge in the top right corner must be lifted up.
  7. Toshiba Chromebook 2 Charging Port Replacement: 7 단계, 이미지 3개 중 1개 Toshiba Chromebook 2 Charging Port Replacement: 7 단계, 이미지 3개 중 2개 Toshiba Chromebook 2 Charging Port Replacement: 7 단계, 이미지 3개 중 3개
    • Pry the metal hinge up with the spudger tool by sticking the flat end under the bottom of the hinge and leverage it up.
    • Open the hinge all the way until it is sticking straight up.
  8. Toshiba Chromebook 2 Charging Port Replacement: 8 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Charging Port Replacement: 8 단계, 이미지 2개 중 2개
    • Press down on the white clip with the pointed side of the spudger tool and softly pull the wires out of the socket by pulling horizontally away from the clip to disconnect the charging port from the motherboard.
  9. Toshiba Chromebook 2 Charging Port Replacement: 9 단계, 이미지 1개 중 1개
    • Pull the charging port out by pulling up on the cable that connects the port to the motherboard.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jason Lomsdalen
회원 가입일: 10/06/16
392 평판
안내서 1개를 작성함
Cal Poly, Team 10-4, Livingston Fall 2016 Cal Poly, Team 10-4, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G4
4 회원들
안내서 11개를 작성함
댓글 3개
ok… but what's the part for the charging port itself to replace??
Brian “Deminox” Preston - 답글
The power port part # is either SIQDD0BUHAD000(shorter) or SIQDD0BUIAD000(longer) depending on which model you have.
Tim Nolte - 답글
I removed the damaged port, but don't know which part to order. The third line on the tag is 150104 and all the parts I see when googling have different numbers. The SIQ number is the same.
RS from LA1 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 35
전체 시간: 3,273
