주요 콘텐츠로 건너뛰기
Toshiba Chromebook 2 Speakers Replacement
Alec Marnoch
Alec Marnoch4 다른 기여자
최종 수정일 November 11, 2019
6 분
조정
Over time, speaker quality can degrade for a variety of reasons. Replacing the speakers will fix most issues involving sound and sound quality.
필요한 것
도구
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Toshiba Chromebook 2 Speakers Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Speakers Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Speakers Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Speakers Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Speakers Replacement: 4 단계, 이미지 2개 중 2개
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Speakers Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Speakers Replacement, Battery: 6 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Speakers Replacement, Battery: 6 단계, 이미지 2개 중 2개
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Speakers Replacement: 7 단계, 이미지 2개 중 1개 Toshiba Chromebook 2 Speakers Replacement: 7 단계, 이미지 2개 중 2개
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Speakers Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the battery by gently pulling up on the bottom corners.
  9. Toshiba Chromebook 2 Speakers Replacement, Speakers: 9 단계, 이미지 1개 중 1개
    • Remove the 2 3.3 mm screws holding the left and right speakers with the Phillips #0 screwdriver.
  10. Toshiba Chromebook 2 Speakers Replacement: 10 단계, 이미지 3개 중 1개 Toshiba Chromebook 2 Speakers Replacement: 10 단계, 이미지 3개 중 2개 Toshiba Chromebook 2 Speakers Replacement: 10 단계, 이미지 3개 중 3개
    • Pull the red and white wires out of the socket above the left speaker to disconnect the speakers from the motherboard.
  11. Toshiba Chromebook 2 Speakers Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the speakers by lifting upwards.
    • Wiring connecting the left and right speakers may be taped to the top of the battery. Simply remove the tape to remove the speakers.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alec Marnoch
회원 가입일: 10/06/16
257 평판
안내서 1개를 작성함
Cal Poly, Team 10-4, Livingston Fall 2016 Cal Poly, Team 10-4, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G4
4 회원들
안내서 11개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 11
전체 시간: 797
