주요 콘텐츠로 건너뛰기
Toshiba Dynabook T552-58G Back Panel Replacement
필요한 것
  1. Toshiba Dynabook T552-58G Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn the Toshiba Dynabook T552-58G so that the back panel is facing you.
  2. Toshiba Dynabook T552-58G Back Panel Replacement: 2 단계, 이미지 1/2 Toshiba Dynabook T552-58G Back Panel Replacement: 2 단계, 이미지 2/2
    • Remove the 10 screws located on the back panel of the Toshiba Dynabook T552-58G using a PH 0 screwdriver.
    • Each screw will be 5.3 mm long.
  3. Toshiba Dynabook T552-58G Back Panel Replacement: 3 단계, 이미지 1/3 Toshiba Dynabook T552-58G Back Panel Replacement: 3 단계, 이미지 2/3 Toshiba Dynabook T552-58G Back Panel Replacement: 3 단계, 이미지 3/3
    • Remove the black screw using the J0 screwdriver. This is located by the top right foot of the device.
    • This will allow removal of the hard drive cover.
    • This screw will not come out of the hard drive cover.
  4. Toshiba Dynabook T552-58G Back Panel Replacement: 4 단계, 이미지 1/1
    • Remove the single screw located below the hard drive using the J0 screwdriver. This screw is 5.3 mm long.
  5. Toshiba Dynabook T552-58G Back Panel Replacement: 5 단계, 이미지 1/3 Toshiba Dynabook T552-58G Back Panel Replacement: 5 단계, 이미지 2/3 Toshiba Dynabook T552-58G Back Panel Replacement: 5 단계, 이미지 3/3
    • Remove two screws located diagonally from the bottom-left screw of the hard drive using a J0 screwdriver. The screw closest to the hard drive is 5.2 mm long and the screw farther away is 4.2 mm long.
    • Remove the screw located diagonally from the top right screw of the hard drive using a J0 screwdriver. This screw is 5.2 mm long.
  6. Toshiba Dynabook T552-58G Back Panel Replacement: 6 단계, 이미지 1/3 Toshiba Dynabook T552-58G Back Panel Replacement: 6 단계, 이미지 2/3 Toshiba Dynabook T552-58G Back Panel Replacement: 6 단계, 이미지 3/3
    • Slowly lift the back panel away from the computer.
    • There should be some resistance.
    • Once lifted, carefully remove the back panel.
결론
Laney Pilkington
회원 가입일: 01/31/19
329 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 577
