주요 콘텐츠로 건너뛰기
Toshiba Dynabook T552-58G Hard Drive Replacement
Laney Pilkington
Laney Pilkington2 다른 기여자
최종 수정일 February 20, 2023
15 분
쉬움
If your computer is crashing, or your computer’s hard drive has been damaged, use this guide to replace the hard drive. By following this guide, you will be able to replace the hard drive with little difficulty.
필요한 것
도구
  1. Toshiba Dynabook T552-58G Hard Drive Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Turn the Toshiba Dynabook T552-58G so that the back panel is facing you.
  2. Toshiba Dynabook T552-58G Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Dynabook T552-58G Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 10 screws located on the back panel of the Toshiba Dynabook T552-58G using a PH 0 screwdriver.
    • Each screw will be 5.3 mm long.
  3. Toshiba Dynabook T552-58G Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Dynabook T552-58G Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Dynabook T552-58G Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the black screw using the J0 screwdriver. This is located by the top right foot of the device.
    • This will allow removal of the hard drive cover.
    • This screw will not come out of the hard drive cover.
  4. Toshiba Dynabook T552-58G Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the single screw located below the hard drive using the J0 screwdriver. This screw is 5.3 mm long.
  5. Toshiba Dynabook T552-58G Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 Toshiba Dynabook T552-58G Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 Toshiba Dynabook T552-58G Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Remove two screws located diagonally from the bottom-left screw of the hard drive using a J0 screwdriver. The screw closest to the hard drive is 5.2 mm long and the screw farther away is 4.2 mm long.
    • Remove the screw located diagonally from the top right screw of the hard drive using a J0 screwdriver. This screw is 5.2 mm long.
  6. Toshiba Dynabook T552-58G Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 Toshiba Dynabook T552-58G Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 Toshiba Dynabook T552-58G Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Slowly lift the back panel away from the computer.
    • There should be some resistance.
    • Once lifted, carefully remove the back panel.
  7. Toshiba Dynabook T552-58G Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1개 중 1개
    • The hard drive is located in the under the L-shaped panel on the back of the computer.
  8. Toshiba Dynabook T552-58G Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Carefully push the hard drive to the left
  9. Toshiba Dynabook T552-58G Hard Drive Replacement: 9 단계, 이미지 1개 중 1개
    • Gently lift the hard drive using your fingers.
결론
작성자
2다른 기여자 명과 함께
Laney Pilkington
회원 가입일: 01/31/19
332 평판
안내서 2개를 작성함
댓글 한 개
Está em inglês deveria ter como traduzir aqui dentro da plataforma
Standley Richande - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 28
전체 시간: 748
