주요 콘텐츠로 건너뛰기
Toshiba Dynabook T552-58G Screen Replacement
Courtney Orange
Courtney Orange3 다른 기여자
최종 수정일 May 16, 2024
25 분
어려움
Fix your computer’s screen with ease by following this guide.
If your screen is busted, malfunctioning, or just needs to be replaced, this guide will assist you through the process. For best results, all steps should be followed.
필요한 것
도구
더보기...
  1. Toshiba Dynabook T552-58G Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
  2. Toshiba Dynabook T552-58G Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Using a PH 00 screwdriver, unscrew the four screws in each corner of the screen cover. Each screw is 3.3 mm long.
  3. Toshiba Dynabook T552-58G Screen Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Dynabook T552-58G Screen Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Dynabook T552-58G Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Using your fingers, pull the screen covering off.
    • The cover should pop off.
  4. Toshiba Dynabook T552-58G Screen Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Dynabook T552-58G Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Using a PH 0 screwdriver, unscrew the screws connecting the front cover to the screen. There are two and each screw is 3.4 mm long.
  5. Toshiba Dynabook T552-58G Screen Replacement: 5 단계, 이미지 3개 중 1개 Toshiba Dynabook T552-58G Screen Replacement: 5 단계, 이미지 3개 중 2개 Toshiba Dynabook T552-58G Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Using your fingers, pull the wires from the backing of the front cover.
    • Disconnect the wire from the front cover.
  6. Toshiba Dynabook T552-58G Screen Replacement: 6 단계, 이미지 3개 중 1개 Toshiba Dynabook T552-58G Screen Replacement: 6 단계, 이미지 3개 중 2개 Toshiba Dynabook T552-58G Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Using a PH 0 screwdriver, remove the screws from each side of the screen. There are a total of six screws. Each screw is 3.2 mm long.
  7. Toshiba Dynabook T552-58G Screen Replacement: 7 단계, 이미지 3개 중 1개 Toshiba Dynabook T552-58G Screen Replacement: 7 단계, 이미지 3개 중 2개 Toshiba Dynabook T552-58G Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Remove wire from the back of the screen by just lifting and pulling it.
  8. Toshiba Dynabook T552-58G Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Gently remove screen from the rest of the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Courtney Orange
회원 가입일: 01/31/19
351 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 30
전체 시간: 788
