주요 콘텐츠로 건너뛰기
Toshiba NB205 N330PK Key Cleaning
Mason McCaskill
Mason McCaskill4 다른 기여자
최종 수정일 February 24, 2023
5 분
매우 쉬움
더 나은 소개글
필요한 것
도구
  • Spudger
    Spudger
  • Detailing Brush
    Detailing Brush
  1. Toshiba NB205 N330PK Key Cleaning, Toshiba NB205 N330PK Key Cleaning: 1 단계, 이미지 1개 중 1개
    • Using the spudger, gently pry the desired key up on one side. This will release the key.
    • The key is held in place by very small plastic pieces. Improper removal or installation may damage key permanently and require entire keyboard replacement.
  2. Toshiba NB205 N330PK Key Cleaning: 2 단계, 이미지 2개 중 1개 Toshiba NB205 N330PK Key Cleaning: 2 단계, 이미지 2개 중 2개
    • Use a brush to remove debris and use a cleaner cloth to remove residue.
    • Similarly, remove debris and residue from the area of the keyboard where the key was originally seated.
  3. Toshiba NB205 N330PK Key Cleaning: 3 단계, 이미지 1개 중 1개
    • Once clean, set the key above its original position and firmly press it back into place.
    • If cleaned and installed properly the key should depress smoothly and spring back to normal position once released.
결론
This is a complete guide to removing a key and cleaning the area before replacement.
작성자
4다른 기여자 명과 함께
Mason McCaskill
회원 가입일: 10/18/13
1,021 평판
안내서 9개를 작성함
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013 회원
CLEM-BENSON-F13S14G2
3 회원들
안내서 27개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 525
