주요 콘텐츠로 건너뛰기
Toshiba NB205 N330PK Keyboard Replacement
Mason McCaskill
Mason McCaskill8 다른 기여자
최종 수정일 January 9, 2025
15 분
쉬움
일관성 없는 이미지
마크업 사고
This step-by-step guide outlines how to replace the keyboard on the Toshiba NB205 N330PK. The guide will help to restore the connection by removing the battery, reestablishing the electrical connection, and reattaching or replacing the keyboard.
An out-of-date computer program may cause keyboard failure. However, if updating or clearing unused data from the device does not work, the issue lies in the computer’s external hardware, a physical component of the device. After extended use, the keyboard’s electrical connection will falter, resulting in the laptop display registering some or no keyboard inputs.
Upon completing this repair, you can restore your keyboard’s electrical connection. Before starting the repair, power down the device and disconnect any external power sources to start battery removal.
필요한 것
도구
더보기...
  1. Toshiba NB205 N330PK Keyboard Replacement, Power Button: 1 단계, 이미지 2개 중 1개 Toshiba NB205 N330PK Keyboard Replacement, Power Button: 1 단계, 이미지 2개 중 2개
    • Start by first removing the battery.
    • Move the first release switch to the right position.
    • Move the second release switch to the right position while pulling the battery towards the top of the netbook.
  2. Toshiba NB205 N330PK Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Toshiba NB205 N330PK Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
    • Using the bit driver and a Phillips #0 Bit, remove the two circled screws labelled F6. (These hold the keyboard) one screw may be under a rubber stopper
  3. Toshiba NB205 N330PK Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Toshiba NB205 N330PK Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • While holding the top of the netbook, flip the netbook over.
  4. Toshiba NB205 N330PK Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Toshiba NB205 N330PK Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully lift off the power bar assembly for access to the button and receiver.
  5. Toshiba NB205 N330PK Keyboard Replacement, Keyboard: 5 단계, 이미지 2개 중 1개 Toshiba NB205 N330PK Keyboard Replacement, Keyboard: 5 단계, 이미지 2개 중 2개
    • Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
  6. Toshiba NB205 N330PK Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Toshiba NB205 N330PK Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Reach under the keyboard and disconnect the electrical connection.
    • Lift the broken keyboard off.
  7. Toshiba NB205 N330PK Keyboard Replacement: 7 단계, 이미지 3개 중 1개 Toshiba NB205 N330PK Keyboard Replacement: 7 단계, 이미지 3개 중 2개 Toshiba NB205 N330PK Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Reattach the new electrical connection into the old connection location.
    • Place the keyboard into the original location starting with the bottom first.
    • Gently press the keyboard down to secure it into its original location.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Mason McCaskill
회원 가입일: 10/18/13
1,021 평판
안내서 9개를 작성함
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013 회원
CLEM-BENSON-F13S14G2
3 회원들
안내서 27개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 940
