주요 콘텐츠로 건너뛰기
Toshiba NB205 N330PK Webcam Replacement
Mason McCaskill
Mason McCaskill7 다른 기여자
최종 수정일 January 21, 2025
30 분
조정
더 나은 소개글
필요한 것
부품
도구
더보기...
  1. Toshiba NB205 N330PK Webcam Replacement, Webcam: 1 단계, 이미지 2개 중 1개 Toshiba NB205 N330PK Webcam Replacement, Webcam: 1 단계, 이미지 2개 중 2개
    • Use a spudger to remove the small rubber screw coverings above each retaining screw.
    • Use the bit driver with a Phillips #0 bit to remove the two 5 mm screws securing the screen bezel.
  2. Toshiba NB205 N330PK Webcam Replacement: 2 단계, 이미지 3개 중 1개 Toshiba NB205 N330PK Webcam Replacement: 2 단계, 이미지 3개 중 2개 Toshiba NB205 N330PK Webcam Replacement: 2 단계, 이미지 3개 중 3개
    • Using a spudger, gently pry the screen bezel to the condition of the photograph.
    • For this procedure, it is not necessary to completely removal screen bezel so in order to reduce work, bezel is just partially removed.
  3. Toshiba NB205 N330PK Webcam Replacement: 3 단계, 이미지 2개 중 1개 Toshiba NB205 N330PK Webcam Replacement: 3 단계, 이미지 2개 중 2개
    • Use tweezers to gently remove the connector to the webcam by pulling the plug to the right (per orientation of the photo).
    • Allow the removed wire to hang in place but make note of alignment with respect to webcam.
    • This step is performed while holding down the bezel which is only partially detached.
  4. Toshiba NB205 N330PK Webcam Replacement: 4 단계, 이미지 3개 중 1개 Toshiba NB205 N330PK Webcam Replacement: 4 단계, 이미지 3개 중 2개 Toshiba NB205 N330PK Webcam Replacement: 4 단계, 이미지 3개 중 3개
    • Use the spudger to pry each side of the webcam until it releases from its adhesive back.
  5. Toshiba NB205 N330PK Webcam Replacement: 5 단계, 이미지 2개 중 1개 Toshiba NB205 N330PK Webcam Replacement: 5 단계, 이미지 2개 중 2개
    • Position the new webcam in the old webcam's position. The webcam must be carefully aligned in order to function properly with the bezel in place. Align the hole of the webcam assembly over the cylinder of the webcam stabilizer.
    • Reconnect the electrical connection.
  6. Toshiba NB205 N330PK Webcam Replacement: 6 단계, 이미지 3개 중 1개 Toshiba NB205 N330PK Webcam Replacement: 6 단계, 이미지 3개 중 2개 Toshiba NB205 N330PK Webcam Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Gently press the front bezel back into its original position.
    • Using the bit driver and Phillips #0 bit, drive the two bezel retaining screws in to place.
    • Cover the screws with the small covers with tweezers.
결승점
작성자
7다른 기여자 명과 함께
Mason McCaskill
회원 가입일: 10/18/13
1,021 평판
안내서 9개를 작성함
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013 회원
CLEM-BENSON-F13S14G2
3 회원들
안내서 27개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 597
