주요 콘텐츠로 건너뛰기
Toshiba NB305 Keyboard  Replacement
Nuri Chung
Nuri Chung3 다른 기여자
최종 수정일 February 25, 2023
10 - 20 분
조정
When replacing your keyboard make sure that you are not to rough with the removal of the keyboard. Take your time and go slowly or you will run the risk of damaging the laptop. Replacing your keyboard can help with efficiency and make working on your leptop more productive.
필요한 것
도구
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
더보기...
  1. Toshiba NB305 Keyboard  Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 Keyboard  Replacement: 2 단계, 이미지 1개 중 1개
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 Keyboard  Replacement: 3 단계, 이미지 2개 중 1개 Toshiba NB305 Keyboard  Replacement: 3 단계, 이미지 2개 중 2개
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 Keyboard  Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 Toshiba NB305 Keyboard  Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Remove the four F4 screws and the F6 screw underneath battery.
    • 4mm Phillips-0 screws.
    • 6mm Phillips-0 screws.
  5. Toshiba NB305 Keyboard  Replacement: 5 단계, 이미지 3개 중 1개 Toshiba NB305 Keyboard  Replacement: 5 단계, 이미지 3개 중 2개 Toshiba NB305 Keyboard  Replacement: 5 단계, 이미지 3개 중 3개
    • Using a spudger, gently pry out on the plastic cover.
    • Turn it over and remove plastic cover on top of laptop with power button on it.
  6. Toshiba NB305 Keyboard  Replacement: 6 단계, 이미지 2개 중 1개 Toshiba NB305 Keyboard  Replacement: 6 단계, 이미지 2개 중 2개
    • Use the plastic opening tool in little notches above the keyboard
    • Gently pry up on the keyboard until it lifts up.
    • You might hear a click when the keyboard releases.
  7. Toshiba NB305 Keyboard  Replacement: 7 단계, 이미지 1개 중 1개
    • Gently lift the keyboard up toward the screen.
    • Be careful! There is a cable still connected from the computer to the keyboard.
  8. Toshiba NB305 Keyboard  Replacement: 8 단계, 이미지 2개 중 1개 Toshiba NB305 Keyboard  Replacement: 8 단계, 이미지 2개 중 2개
    • The ribbon cable has a clip on each side holding it to the motherboard.
    • Using a spudger, press on the clips to release the cable.
    • The cable will slide out on its own when it is properly released.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nuri Chung
회원 가입일: 10/25/16
377 평판
안내서 3개를 작성함
USF Tampa, Team 5-5, Lacy Fall 2016 USF Tampa, Team 5-5, Lacy Fall 2016 회원
USFT-LACY-F16S5G5
3 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 6
전체 시간: 796
