주요 콘텐츠로 건너뛰기
Toshiba Portege Z835-P330 Battery Replacement
Dominic Whiting
Dominic Whiting4 다른 기여자
최종 수정일 February 26, 2023
20 분
조정
This guide will teach you how to replace the battery of the Toshiba Portege Z835-P330.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Toshiba Portege Z835-P330 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the thirteen 1.4mm screws on back of device using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Locate hidden screw found in the middle of back hardcover.
    • Found under rubber covering shown in picture.
    • Remove the single Torx Security screw using a TR7 screwdriver.
  3. Toshiba Portege Z835-P330 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Peel off hardcover to expose interior of device.
    • Force may be required but hardcover should detach smoothly.
  4. Toshiba Portege Z835-P330 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the six 1 mm screws using a Phillips #1 screwdriver.
  5. Toshiba Portege Z835-P330 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the white plug connected to the battery by gently pulling it out of the socket.
    • Plug should easily detach without force.
  6. Toshiba Portege Z835-P330 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Lift battery up by its sides, and it should easily come off.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Dominic Whiting
회원 가입일: 02/08/18
927 평판
안내서 5개를 작성함
댓글 6개
These steps also work for the Z935-P300. NOTE: the center screw in step two is a Torx Security TR7.
Jim Flattery - 답글
Will it lose it’s memory when the power and battery are disconnected? Do I need to back it up before I do this? My battery is so dead that the laptop shuts down after just a few minutes without the ac cord plugged in.
Thank you!
pat_brady_pb@yahoo.com - 답글
I suspect you have already completed your repair and now know the answer, however, in the event that you are still waiting on a response. The short answer is no, the storage drive will not loose data when changing the battery. Despite this, it is always wise to have a backup.
Jim Flattery -
Could anyone please tell me which type of screws are these ?
lourencopintodasilva - 답글
Which screws are you referring to? I believe they all have their details size and type listed above. Is there one in particular you need further detail on?
Jim Flattery -
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 49
전체 시간: 4,698
