주요 콘텐츠로 건너뛰기
Toshiba Qosmio X775-3DV80 Motherboard Replacement
Jesse Adam Ory
Jesse Adam Ory다른 한 명의 기여자
최종 수정일 March 4, 2023
30 분
조정
누락된 단계
경관 도로
더 나은 소개글
필요한 것
도구
더보기...
  1. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Toshiba Qosmio X775-3DV80 Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Qosmio X775-3DV80 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Optical Drive: 4 단계, 이미지 1개 중 1개
    • Locate the optical drive retaining screw on the underside of the laptop.
  5. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the optical drive retaining screw.
  6. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Toshiba Qosmio X775-3DV80 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Using your finger or a spudger, push the optical drive out of its compartment so you can grab it.
    • Pull the optical drive out of its slot in the side of the laptop.
  7. Toshiba Qosmio X775-3DV80 Motherboard Replacement, RAM: 7 단계, 이미지 1개 중 1개
    • Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
    • It is a captive screw that will remain attached to the service panel.
  8. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Using a spudger or plastic opening tool, pry off the service panel.
  9. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Toshiba Qosmio X775-3DV80 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Toshiba Qosmio X775-3DV80 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Using your fingers, pull the retaining clips away from the RAM sticks.
    • Pull the RAM sticks out of the slots.
  10. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Keyboard: 10 단계, 이미지 2개 중 1개 Toshiba Qosmio X775-3DV80 Motherboard Replacement, Keyboard: 10 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove all the remaining fourteen screws from the bottom case of the laptop.
    • The service panel should already be removed.
  11. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Toshiba Qosmio X775-3DV80 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the five screws under the service panel.
    • Remove the retaining clip.
  12. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Using a spudger, pry the keyboard from the top panel of the laptop.
    • Make sure to pry it off all around.
  13. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 13 단계, 이미지 3개 중 1개 Toshiba Qosmio X775-3DV80 Motherboard Replacement: 13 단계, 이미지 3개 중 2개 Toshiba Qosmio X775-3DV80 Motherboard Replacement: 13 단계, 이미지 3개 중 3개
    • Disconnect the two ribbon cables connecting the keyboard to the laptop.
    • Unplug the connector on the bottom of the laptop.
  14. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Fan: 14 단계, 이미지 1개 중 1개
    • Separate the two halves of the base of the laptop.
  15. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 Toshiba Qosmio X775-3DV80 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    • Disconnect the two cables.
  16. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the palmrest assembly.
  17. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 17 단계, 이미지 2개 중 1개 Toshiba Qosmio X775-3DV80 Motherboard Replacement: 17 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the four screws securing the fan assembly to the laptop.
  18. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 18 단계, 이미지 2개 중 1개 Toshiba Qosmio X775-3DV80 Motherboard Replacement: 18 단계, 이미지 2개 중 2개
    • Unplug the fan-motherboard connector.
    • Remove the fan unit.
  19. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Wifi Chip: 19 단계, 이미지 1개 중 1개
    • Detach the two coaxial connections from the wifi chip.
  20. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 20 단계, 이미지 2개 중 1개 Toshiba Qosmio X775-3DV80 Motherboard Replacement: 20 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the two screws from the wifi chip.
  21. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 21 단계, 이미지 1개 중 1개
    • Remove the wifi chip by pulling it out of the PCIe slot.
  22. Toshiba Qosmio X775-3DV80 Motherboard Replacement, Motherboard: 22 단계, 이미지 3개 중 1개 Toshiba Qosmio X775-3DV80 Motherboard Replacement, Motherboard: 22 단계, 이미지 3개 중 2개 Toshiba Qosmio X775-3DV80 Motherboard Replacement, Motherboard: 22 단계, 이미지 3개 중 3개
    • Disconnect the three ribbon cables.
  23. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 23 단계, 이미지 3개 중 1개 Toshiba Qosmio X775-3DV80 Motherboard Replacement: 23 단계, 이미지 3개 중 2개 Toshiba Qosmio X775-3DV80 Motherboard Replacement: 23 단계, 이미지 3개 중 3개
    • Using a Phillips #00 screwdriver, remove the four screws securing the motherboard to the laptop.
  24. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 24 단계, 이미지 1개 중 1개
    • Disconnect the pinned connector.
  25. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 25 단계, 이미지 1개 중 1개
    • Remove the 4-pin connector housing by gently wiggling it back and forth.
  26. Toshiba Qosmio X775-3DV80 Motherboard Replacement: 26 단계, 이미지 1개 중 1개
    • Remove the motherboard.
결론
작성자
1다른 기여자 명과 함께
Jesse Adam Ory
회원 가입일: 03/24/19
745 평판
안내서 7개를 작성함
UMass Dartmouth, Team S2-G1, Bailey Spring 2019 UMass Dartmouth, Team S2-G1, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G1
4 회원들
안내서 21개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 4
지난 30일: 13
전체 시간: 1,181
