주요 콘텐츠로 건너뛰기
Toshiba Qosmio X775-3DV80 RAM Replacement
Jesse Adam Ory
Jesse Adam Ory4 다른 기여자
최종 수정일 March 4, 2023
3 분
쉬움
This guide will demonstrate how to change the RAM (random access memory) in a Toshiba Qosmio X775-3DV80. RAM is used as storage for temporary data. Browsers, media players, and applications are just some of the programs that utilize the quick access
RAM to function.
Computers with more RAM can run a greater amount of programs simultaneously. As such, installing larger RAM sticks is one of the best and simplest methods for upgrading your laptop. Whether you’re upgrading or replacing faulty sticks, this guide can help.
For additional information on this laptop’s RAM, please refer to the manual found here:
Toshiba Qosmio X775-3DV80 Manual
Before starting, please make sure to turn off and unplug the computer. The RAM may be hot if the computer has been running recently.
필요한 것
도구
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
더보기...
  1. Toshiba Qosmio X775-3DV80 RAM Replacement, Battery: 1 단계, 이미지 2개 중 1개 Toshiba Qosmio X775-3DV80 RAM Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 RAM Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Qosmio X775-3DV80 RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 RAM Replacement, RAM: 4 단계, 이미지 1개 중 1개
    • Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
    • It is a captive screw that will remain attached to the service panel.
  5. Toshiba Qosmio X775-3DV80 RAM Replacement: 5 단계, 이미지 1개 중 1개
    • Using a spudger or plastic opening tool, pry off the service panel.
  6. Toshiba Qosmio X775-3DV80 RAM Replacement: 6 단계, 이미지 3개 중 1개 Toshiba Qosmio X775-3DV80 RAM Replacement: 6 단계, 이미지 3개 중 2개 Toshiba Qosmio X775-3DV80 RAM Replacement: 6 단계, 이미지 3개 중 3개
    • Using your fingers, pull the retaining clips away from the RAM sticks.
    • Pull the RAM sticks out of the slots.
결론
작성자
4다른 기여자 명과 함께
Jesse Adam Ory
회원 가입일: 03/24/19
745 평판
안내서 7개를 작성함
UMass Dartmouth, Team S2-G1, Bailey Spring 2019 UMass Dartmouth, Team S2-G1, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G1
4 회원들
안내서 21개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 4
전체 시간: 450
