주요 콘텐츠로 건너뛰기
Toshiba Satellite A105-S4284  Hard Drive Replacement
pfedigan
pfedigan7 다른 기여자
최종 수정일 May 14, 2023
5 - 10 분
쉬움
The hard drive is the storage space of your computer, containing your music, photos, programs, and documents. It also houses your operating system. Save all the files you want to keep on an external device before installing a new hard drive, as replacing the hard drive basically gives you a new computer.
필요한 것
도구
  1. Toshiba Satellite A105-S4284  Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 Toshiba Satellite A105-S4284  Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284  Hard Drive Replacement, Hard Drive: 2 단계, 이미지 3개 중 1개 Toshiba Satellite A105-S4284  Hard Drive Replacement, Hard Drive: 2 단계, 이미지 3개 중 2개 Toshiba Satellite A105-S4284  Hard Drive Replacement, Hard Drive: 2 단계, 이미지 3개 중 3개
    • Turn the laptop around 180 degrees.
    • Unscrew the 4 mm screw with the Philips #1 screwdriver.
    • Lift and remove the hard drive cover.
  3. Toshiba Satellite A105-S4284  Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Satellite A105-S4284  Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Satellite A105-S4284  Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Pull on the rubber tab to slide the hard drive to the left.
    • Pick up the near side of the hard drive and pull it out the back.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
pfedigan
회원 가입일: 04/12/13
11 평판
안내서 4개를 작성함
Cal Poly, Team 2-23, Maness Spring 2013 Cal Poly, Team 2-23, Maness Spring 2013 회원
CPSU-MANESS-S13S2G23
4 회원들
안내서 13개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 20
전체 시간: 2,527
