Toshiba Satellite A105-S4284 Battery Replacement
If your computer is not turning on or holding a charge, it might be time for a new battery. This guide will show you how to remove and install your Toshiba satellite A105-S4284 battery.
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
다른 2명이 해당 안내서를 완성하였습니다.
