Toshiba Satellite A105-S4284 Disc Drive Replacement
10 분
조정
더 나은 소개글
If your CDs or DVDs are not running correctly or at all on your computer, then it is either due to the disc drive being dirty, loose parts and/or broken. This guide will show the user how to safely remove the disc drive.
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
거의 끝나갑니다!
결론
