주요 콘텐츠로 건너뛰기
Toshiba Satellite A105-S4284 Keyboard Replacement
pfedigan
pfedigan9 다른 기여자
최종 수정일 December 4, 2023
10 - 20 분
조정
더 나은 소개글
If your keys are not typing anything or the way they should, then check this guide to see how to safely remove and replace the keyboard input device on the computer. It will also contain detailed pictures on what to expect and watch out for, such as ribbons or wires.
필요한 것
도구
  1. Toshiba Satellite A105-S4284 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Toshiba Satellite A105-S4284 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 Keyboard Replacement, Keyboard: 2 단계, 이미지 1개 중 1개
    • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  3. Toshiba Satellite A105-S4284 Keyboard Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Satellite A105-S4284 Keyboard Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Satellite A105-S4284 Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
    • Use the plastic opening tool to pop off tabs along the length of this panel.
    • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  4. Toshiba Satellite A105-S4284 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Satellite A105-S4284 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  5. Toshiba Satellite A105-S4284 Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Toshiba Satellite A105-S4284 Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Toshiba Satellite A105-S4284 Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Lift the keyboard gently from the side closest the screen.
    • Pull out the ribbon connecting the keyboard to the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
pfedigan
회원 가입일: 04/12/13
11 평판
안내서 4개를 작성함
Cal Poly, Team 2-23, Maness Spring 2013 Cal Poly, Team 2-23, Maness Spring 2013 회원
CPSU-MANESS-S13S2G23
4 회원들
안내서 13개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 16
전체 시간: 1,511
