주요 콘텐츠로 건너뛰기
Toshiba Satellite A105-S4284 Trackpad Replacement
Josh
Josh3 다른 기여자
최종 수정일 November 1, 2022
30 분
조정
Some times the computers trackpad can become unreliable or unresponsive. It is possible to remove the track pad to clean the connections. and reinstall.
필요한 것
도구
  1. Toshiba Satellite A105-S4284 Trackpad Replacement, Battery: 1 단계, 이미지 2개 중 1개 Toshiba Satellite A105-S4284 Trackpad Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 Trackpad Replacement, Casing: 2 단계, 이미지 3개 중 1개 Toshiba Satellite A105-S4284 Trackpad Replacement, Casing: 2 단계, 이미지 3개 중 2개 Toshiba Satellite A105-S4284 Trackpad Replacement, Casing: 2 단계, 이미지 3개 중 3개
    • Disconnect wire attaching LCD to motherboard
    • Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
    • Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
  3. Toshiba Satellite A105-S4284 Trackpad Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Satellite A105-S4284 Trackpad Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the seventeen 4.5mm phillips screws on the bottom of the laptop.
    • Using the pry tool separate the two halves of the laptop base.
    • Use caution when separating the laptop halves as they are still connected by two ribbon cables.
  4. Toshiba Satellite A105-S4284 Trackpad Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Satellite A105-S4284 Trackpad Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard.
  5. Toshiba Satellite A105-S4284 Trackpad Replacement, Trackpad: 5 단계, 이미지 1개 중 1개
    • the upper half of the computer base.
  6. Toshiba Satellite A105-S4284 Trackpad Replacement: 6 단계, 이미지 2개 중 1개 Toshiba Satellite A105-S4284 Trackpad Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the 3 4.5mm screws holding the track-pad in place.
    • There are some screws that will be hidden by assembly tape.
  7. Toshiba Satellite A105-S4284 Trackpad Replacement: 7 단계, 이미지 1개 중 1개
    • Slide green circuit board to right and lift track pad free from laptop.
결론
작성자
3다른 기여자 명과 함께
Josh
회원 가입일: 03/12/14
685 평판
안내서 5개를 작성함
UMass Dartmouth, Team 1-6, Cichon Spring 2014 UMass Dartmouth, Team 1-6, Cichon Spring 2014 회원
UMASSD-CICHON-S14S1G6
3 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 2
전체 시간: 516
