Toshiba Satellite C655-S5142 Battery Replacement
1 분
매우 쉬움
If your laptop’s battery needs to be removed or replaced, this guide will walk you through the process. You do not need any tools to do this, and it is a relatively simplistic process.
거의 끝나갑니다!
To replace the battery, gently insert it back into the laptop. Once it is secured, make sure both switches are in the “locked” position (pushed towards the battery).
결론
