주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toshiba Satellite C655-S5212 LCD Screen Replacement
Barrington Edman
Barrington Edman3 다른 기여자
최종 수정일 2023년 11월 30일
10 - 15 분
조정
커뮤니티-기여 안내서
This is a guide on how to remove a LCd screen from 15" Toshiba Satellite Laptop. Model # C655-S5212
필요한 것
도구
  1. Toshiba Satellite C655-S5212 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 1개 Toshiba Satellite C655-S5212 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 2개 Toshiba Satellite C655-S5212 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 3개
    • First remove the stickers covers the screws in the 4 corners of LCD case. Stickers are very thin and using utility knife is easiest way to remove without damaging them. After removing stickers unscrew top 2 screws then proceed to Step 2 before trying to remove bottom 2 screws.
  2. Toshiba Satellite C655-S5212 LCD Screen Replacement: 2 단계, 이미지 3개 중 1개 Toshiba Satellite C655-S5212 LCD Screen Replacement: 2 단계, 이미지 3개 중 2개 Toshiba Satellite C655-S5212 LCD Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Turn laptop around to back, and undo the 2 latches in back in order to remove bottom 2 screws of LCD screen. Use your utility knife to slide into crack and push down to unlatch.
  3. Toshiba Satellite C655-S5212 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Satellite C655-S5212 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Once screws are removed, remove cover bezel from LCD very gently without breaking it, you should hear clicking noise when removing.
  4. Toshiba Satellite C655-S5212 LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Satellite C655-S5212 LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Remove 2 screws at bottom of LCD frame and also the 2 screws at top of LCD frame (not pictured). This will allow you to lay the back cover away from frame to access side easier and remove the 3 screws on each side to detach LCD screen. Do not pull LCD once unscrewed, lay down face down on keyboard for last step.
  5. Toshiba Satellite C655-S5212 LCD Screen Replacement: 5 단계, 이미지 3개 중 1개 Toshiba Satellite C655-S5212 LCD Screen Replacement: 5 단계, 이미지 3개 중 2개 Toshiba Satellite C655-S5212 LCD Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Before trying to remove video cable from back of LCD. First gently remove cable from adhesive holding it down to board. Then remove tape from top of cable holding connector in place. Be very gentle at these points.
  6. Toshiba Satellite C655-S5212 LCD Screen Replacement: 6 단계, 이미지 3개 중 1개 Toshiba Satellite C655-S5212 LCD Screen Replacement: 6 단계, 이미지 3개 중 2개 Toshiba Satellite C655-S5212 LCD Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Now gently pull tab to pull cable from slot, be careful not to pull too hard and damage pins when removing. Once removed remove board and install new one.
결론
다른 10명이 해당 안내서를 완성하였습니다.
향후 수리를 위한 준비
모두 쇼핑하기
작성자
3다른 기여자 명과 함께
Barrington Edman
회원 가입일: 07/10/12
1,145 평판
안내서 3개를 작성함
2가이드 댓글
Aoa sir....where to buy a new lcd screen for toshiba core i3??? Plz tell me
kingkhan201189 - 답글
I usually get mine from Amazon or Ebay. On the back of LCD there is a sticker with the model number
Barrington Edman - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 23
전체 시간: 8,272
