주요 콘텐츠로 건너뛰기
Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement
Shelby Kunz
Shelby Kunz8 다른 기여자
최종 수정일 December 9, 2023
5 분
쉬움
If your computer is not recognizing any CD/DVD in the drive, you may have a malfunctioning CD/DVD drive. This installation guide will help you through replacing the CD/DVD drive on the Toshiba Satellite C655D-S5084.
필요한 것
도구
  1. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement, CD/DVD Drive: 1 단계, 이미지 1개 중 1개
    • Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
  2. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement: 2 단계, 이미지 1개 중 1개
    • This step is shown after rotating the device 90 degrees so that the CD drive is closest to you.
    • Wedge a plastic opening tool between the laptop and the CD drive.
    • Gently pull the CD drive out.
  3. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the CD drive completely by pulling out with your hands.
    • The CD drive should come out easily with little force. If there is any resistance double check if 2.5mm "F3" screw is removed completely.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Shelby Kunz
회원 가입일: 04/19/13
69 평판
안내서 5개를 작성함
Cal Poly, Team 2-20, Maness Spring 2013 Cal Poly, Team 2-20, Maness Spring 2013 회원
CPSU-MANESS-S13S2G20
4 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 23
전체 시간: 5,068
