주요 콘텐츠로 건너뛰기
Toshiba Satellite C655D-S5200 Motherboard Replacement
Joseph Sctbunio
Joseph Sctbunio2 다른 기여자
최종 수정일 January 5, 2024
예상시간 없음
조정
커뮤니티-기여 안내서
This guide teaches you how to replace the motherboard in a Toshiba Satellite C655 series laptop.
필요한 것
도구
    • With the battery side facing you, first move the right locking latch to the right.
    • Afterwards, move the left spring latch to the left, but keep your finger there, and pull the battery out with your other hand.
  1. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove hard drive cover: 2 단계, 이미지 1개 중 1개
    • Remove the single screw securing the hard drive cover to the base.
  2. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove hard drive caddy: 3 단계, 이미지 1개 중 1개
    • Remove the single screw securing the hard drive caddy to the base.
  3. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove hard drive from caddy: 4 단계, 이미지 1개 중 1개
    • This step is unnecessary if you're just removing the hard drive for testing purposes, or to replace the motherboard.
    • Remove the four screws securing the hard drive to the caddy.
    • You're done!
  4. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove some screws: 5 단계, 이미지 1개 중 1개
    • Remove the twelve "F6"/M2.5x6 screws.
    • Remove the two "F2" screws under where the battery was.
    • Remove the "F3" screw securing the optical drive, and slide the optical drive out.
    • Remove the two "F2" screws from where the optical drive faceplate was.
    • Remove the memory cover screw, pull the memory door open, and remove the two "F6"/M2.5x6 screws from underneath.
    • Use your fingernail or a spudget to get under the keyboard trim, and pry it up. Go along the keyboard trim, pulling it up.
  5. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove keyboard: 7 단계, 이미지 2개 중 1개 Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove keyboard: 7 단계, 이미지 2개 중 2개
    • Remove the four screws securing the keyboard to the palmrest.
    • Lift the keyboard at the top a little, and pull the keyboard towards the screen, so that you see the locking connector below the keyboard.
    • Push the locking connector's lock towards the screen at both the left and the right points, very gently.
    • Pull the now-loose keyboard cable out of the connector.
  6. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove palmrest cables & palmrest: 8 단계, 이미지 1개 중 1개
    • Remove the three palmrest cables from the motherboard, that being the power button cable, the speaker cable, and the touchpad cable.
    • No need to remove any of the other cables yet.
    • Use a spudger to separate the palmrest from the base.
  7. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove fan: 9 단계, 이미지 1개 중 1개
    • Remove the fan cable.
    • Remove the two silver-colored fan screws.
    • Remove the single black-colored fan screw.
  8. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove motherboard: 10 단계, 이미지 1개 중 1개
    • Remove the single screw securing the motherboard to the base.
    • Remove the two wireless antenna connectors.
    • Remove the LCD cable.
    • Lift the motherboard out of the base.
  9. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove the heatsink: 11 단계, 이미지 1개 중 1개
    • Remove the four screws securing the heatsink to the motherboard.
    • Remove the processor, memory, and optionally, the clock battery. Install the first two in the replacement motherboard. You're done!
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Joseph Sctbunio
회원 가입일: 09/23/17
7,527 평판
안내서 42개를 작성함
댓글 한 개
is there any processor upgrades compatible with this specific computer? other than ram and ssd any upgrade info would be appreciated.
robert wallace - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 40
전체 시간: 3,100
