주요 콘텐츠로 건너뛰기
Toshiba Satellite E45-B4200 Back Case Replacement
Sarah Westberg
Sarah Westberg
최종 수정일 June 12, 2023
1 - 3 분
쉬움
In order to do most repairs on your Toshiba Satellite E45-B4200 laptop, you'll need to access the internals of the device. This guide will show you how to remove the back case of your laptop and easily reach the internal components.
Prior to beginning this repair, power down the device, unplug from the charger and remove the external battery. This device did not have the external battery so we weren't able to demonstrate removal.
필요한 것
도구
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
더보기...
  1. Toshiba Satellite E45-B4200 Back Case Replacement, Back Case: 1 단계, 이미지 3개 중 1개 Toshiba Satellite E45-B4200 Back Case Replacement, Back Case: 1 단계, 이미지 3개 중 2개 Toshiba Satellite E45-B4200 Back Case Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Make sure to turn off the device, remove the battery, and unplug the laptop from the charger prior to the disassembly.
    • Use a Phillips #0 screwdriver to remove fourteen 3.75 mm screws from the back cover.
    • Use a spudger or opening tool to gently separate the back cover from the top of the device. Work your way around the perimeter of the laptop and undo the clips with the spudger.
    • Remove the back case.
결론
Sarah Westberg
회원 가입일: 03/11/19
29,390 평판
안내서 71개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,457개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 16
전체 시간: 125
