주요 콘텐츠로 건너뛰기
Toshiba Satellite E45-B4200 Speakers Replacement
Raymond Makynen
Raymond Makynen2 다른 기여자
최종 수정일 June 12, 2023
20 - 40 분
조정
액션 샷
더 많은 이미지가 필요함
The Toshiba Satellite E45-B4200, may eventually have problems with the speakers through faulty wires, bad drivers, etc. This could cause the speakers to crackle, make popping sounds, or have a worse overall audio quality. When this happens, the speakers are replaceable, and this guide will explain how to replace them if this occurs. Before replacement, ensure there aren't any other issues you could have through Toshiba Satellite E45-B4200 Troubleshooting.
Before beginning this repair, be sure to power off the laptop, disconnect from the charger and remove the external battery. This device didn't come with a battery so we weren't able to include images or instruction on removing it.
필요한 것
도구
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #0 Screwdriver
더보기...
  1. Toshiba Satellite E45-B4200 Speakers Replacement, Back Case: 1 단계, 이미지 3개 중 1개 Toshiba Satellite E45-B4200 Speakers Replacement, Back Case: 1 단계, 이미지 3개 중 2개 Toshiba Satellite E45-B4200 Speakers Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Make sure to turn off the device, remove the battery, and unplug the laptop from the charger prior to the disassembly.
    • Use a Phillips #0 screwdriver to remove fourteen 3.75 mm screws from the back cover.
    • Use a spudger or opening tool to gently separate the back cover from the top of the device. Work your way around the perimeter of the laptop and undo the clips with the spudger.
    • Remove the back case.
  2. Toshiba Satellite E45-B4200 Speakers Replacement, Speakers: 2 단계, 이미지 2개 중 1개 Toshiba Satellite E45-B4200 Speakers Replacement, Speakers: 2 단계, 이미지 2개 중 2개
    • To remove the speakers from the motherboard, pull the speaker cables away from the connector in the same direction that the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  3. Toshiba Satellite E45-B4200 Speakers Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Satellite E45-B4200 Speakers Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Satellite E45-B4200 Speakers Replacement: 3 단계, 이미지 3개 중 3개
    • Using a Phillips #0 screwdriver, unscrew the two screws from each speaker, that hold them in place.
    • You don't need to remove the screws, just unscrew them to the point that you're able to remove them from the device.
  4. Toshiba Satellite E45-B4200 Speakers Replacement: 4 단계, 이미지 1개 중 1개
    • Gently remove the speakers from the laptop. Make sure to disconnect the speaker wires from the frame prior to lifting the speakers out.
결론
작성자
2다른 기여자 명과 함께
Raymond Makynen
회원 가입일: 03/20/23
289 평판
안내서 3개를 작성함
UMass Dartmouth, Team 5-2, Ramos Spring 2023 UMass Dartmouth, Team 5-2, Ramos Spring 2023 회원
UMASSD-RAMOS-S23S5G2
3 회원들
안내서 6개를 작성함
댓글 2개
Thanks for the guide, but looks is missing some main parts, the product code of the speaker.
Before I disassembly something I want to buy the replacement, by searching for "toshiba e45-b4200 speaker" I only find some presumably compatible speakers, with different shape.
Any idea of what is the product code?
Thanks
MagenOne - 답글
Looks this H000079200
MagenOne -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 10
전체 시간: 262
