Toshiba Satellite L670 HDD replacement
This guide shows you how to replace the Toshiba Satellite L670 HDD.
Turn the laptop upside down. Locate the two latches on either side of the battery.
Now the battery comes off.
Pull the HDD to the left using the silver tab.
Pull up on the silver tab and remove the hard drive from the slot.
Take your new SSD hard drive.
Place the SSD in the silver case.
Place back the 4 screws you just removed.
Replace the back panel and screw it in place.
Put the battery back in, you will hear a click once it falls into place.
To reassemble the device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
