주요 콘텐츠로 건너뛰기
Toshiba Satellite P55W-C5200X Display Replacement
Hadi Termos
Hadi Termos3 다른 기여자
최종 수정일 March 6, 2023
15 - 25 분
조정
If your Toshiba Satellite P55W-C5200X is experiencing issues such as white spots and colored lines appearing, buzzing or random shutoffs, then it is clear your display is no longer functional. This may be due to the LED monitor, a faulty CFL monitor and/or power adapter. The best course of action is to replace the display assembly before problems become worse.
필요한 것
도구
더보기...
  1. Toshiba Satellite P55W-C5200X Display Replacement, Battery: 1 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement, Battery: 1 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Display Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Display Replacement: 2 단계, 이미지 1개 중 1개
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Display Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Display Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Display Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement: 5 단계, 이미지 2개 중 2개
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Display Replacement, Display: 6 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement, Display: 6 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Display Replacement, Display: 6 단계, 이미지 3개 중 3개
    • Use the Phillips #00 screwdriver to remove the six 5.0 mm screws that are holding the metal brackets on both sides in place.
    • Gently remove both metal brackets.
  7. Toshiba Satellite P55W-C5200X Display Replacement: 7 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement: 7 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Display Replacement: 7 단계, 이미지 3개 중 3개
    • Remove he three wires connected to the motherboard.
  8. Toshiba Satellite P55W-C5200X Display Replacement: 8 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement: 8 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Display Replacement: 8 단계, 이미지 3개 중 3개
    • On the other side remove the four remaining wires from their ports.
  9. Toshiba Satellite P55W-C5200X Display Replacement: 9 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement: 9 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Display Replacement: 9 단계, 이미지 3개 중 3개
    • Lift two sets of metal brackets up, one in each corner.
    • Depending on the force needed on your specific device, you may need to use the spudger.
  10. Toshiba Satellite P55W-C5200X Display Replacement: 10 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Display Replacement: 10 단계, 이미지 2개 중 2개
    • Gently lift the device away from the display assembly.
    • Be aware of the wires attached to the screen so they don't snag on anything.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hadi Termos
회원 가입일: 10/21/19
241 평판
안내서 2개를 작성함
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 UMass Dartmouth, Team S1-G2, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G2
4 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 13
전체 시간: 1,072
