주요 콘텐츠로 건너뛰기
Toshiba Satellite P55W-C5200X Keyboard Replacement
Vatthanak Doeung
Vatthanak Doeung3 다른 기여자
최종 수정일 March 11, 2023
30 - 45 분
어려움
If your Toshiba Satellite P55W-C5200X keyboard is not responding it may be time for a replacement. Keyboards may become unresponsive if there is a build up of dirt or other materials in the keys. If not it may be a more severe problem and would require a full replacement of the keyboard itself.
The tools needed to gain access to the keyboard are listed below . This is a low risk operation, the only requirement for safety is to make sure the device is turned off before starting and keeping away from liquids while working on the device.
This guide will tell Toshiba Satellite P55W-C5200X users how to replace a defective keyboard.
필요한 것
도구
더보기...
  1. Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: 6 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: 6 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: 6 단계, 이미지 3개 중 3개
    • For this particular model of the device there will be two sticks of RAM.
    • There are two metal brackets holding each RAM stick in place. Carefully move the metal brackets outward on both sides at the same time.
    • Pull the RAM sticks out.
  7. Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: 7 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: 7 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: 7 단계, 이미지 3개 중 3개
    • Remove the two 4.0 mm screws using the Phillips #00 screwdriver.
    • Remove the four 2.0 mm screws using the Phillips #0 screwdriver.
  8. Toshiba Satellite P55W-C5200X Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the fan cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  9. Toshiba Satellite P55W-C5200X Keyboard Replacement: 9 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 9 단계, 이미지 2개 중 2개
    • Gently remove the fan from your device.
  10. Toshiba Satellite P55W-C5200X Keyboard Replacement, Keyboard: 10 단계, 이미지 1개 중 1개
    • Once the fan, ram, and battery are removed, remove the motherboard.
    • Detach the three connecting wires.
    • Remove the white, blue-tipped cable ribbon too.
  11. Toshiba Satellite P55W-C5200X Keyboard Replacement: 11 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 11 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 11 단계, 이미지 3개 중 3개
    • Remove the three wires that are connected to the motherboard first.
  12. Toshiba Satellite P55W-C5200X Keyboard Replacement: 12 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the ribbon by using the black nylon spudger to avoid tearing the ribbon.
  13. Toshiba Satellite P55W-C5200X Keyboard Replacement: 13 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 13 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 13 단계, 이미지 3개 중 3개
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal bracket in place.
    • Gently remove the metal bracket.
  14. Toshiba Satellite P55W-C5200X Keyboard Replacement: 14 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 14 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 14 단계, 이미지 3개 중 3개
    • Use the Phillips #00 to remove the four 8.0 mm screws that are holding the motherboard in place.
    • After removing all the screws, gently remove the motherboard.
  15. Toshiba Satellite P55W-C5200X Keyboard Replacement: 15 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 15 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 15 단계, 이미지 3개 중 3개
    • Similar to step 4, there is a metal bracket that must be removed to get to some ports.
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal plate in place.
    • Gently remove the metal bracket off the ports underneath.
  16. Toshiba Satellite P55W-C5200X Keyboard Replacement: 16 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 16 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 16 단계, 이미지 3개 중 3개
    • Once the ports are accessible, remove four connecting wires from the ports themselves.
    • Be gentle when removing the four wires.
  17. Toshiba Satellite P55W-C5200X Keyboard Replacement: 17 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 17 단계, 이미지 2개 중 2개
    • Once the connecting wires are removed, remove the 8.0 mm screw of the USB ports, using the Phillips #00 screwdriver.
    • Gently remove the USB ports.
  18. Toshiba Satellite P55W-C5200X Keyboard Replacement: 18 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 18 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 18 단계, 이미지 3개 중 3개
    • Remove the thirty-three 1.0 mm screws with the Phillips Head #000.
    • Gently remove the metal cover.
  19. Toshiba Satellite P55W-C5200X Keyboard Replacement: 19 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 19 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X Keyboard Replacement: 19 단계, 이미지 3개 중 3개
    • Gently pull on the tab to lift the keyboard from the device.
    • Lastly remove the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Vatthanak Doeung
회원 가입일: 10/21/19
223 평판
안내서 1개를 작성함
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 UMass Dartmouth, Team S1-G2, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G2
4 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 14
지난 30일: 20
전체 시간: 1,674
