주요 콘텐츠로 건너뛰기
Toshiba Satellite P55W-C5200X RAM Replacement
Hadi Termos
Hadi Termos3 다른 기여자
최종 수정일 March 6, 2023
10 분
쉬움
Is your Toshiba Satellite P55W-C5200X running very slowly and slow to respond, or is it not even turning the screen on? The cause may lay with a faulty or mismatched RAM. You may not have enough RAM or may not have a compatible type to your motherboard. For any of these reasons a replacement or change may be in order.
All tools that will be needed are listed below to gain access and change out your devices RAM. This is a very simple process and low risk as well, the only advise would be to make sure the device is turned off and to be careful when handling the RAM and the slots they go into.
This guide will tell Toshiba Satellite P55W-C5200X users how to replace there RAM. It is an easy-level process that takes 5-10 minutes to complete.
필요한 것
도구
더보기...
  1. Toshiba Satellite P55W-C5200X RAM Replacement, Battery: 1 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X RAM Replacement, Battery: 1 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X RAM Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X RAM Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X RAM Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X RAM Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X RAM Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Satellite P55W-C5200X RAM Replacement: 5 단계, 이미지 2개 중 2개
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X RAM Replacement, RAM: 6 단계, 이미지 3개 중 1개 Toshiba Satellite P55W-C5200X RAM Replacement, RAM: 6 단계, 이미지 3개 중 2개 Toshiba Satellite P55W-C5200X RAM Replacement, RAM: 6 단계, 이미지 3개 중 3개
    • For this particular model of the device there will be two sticks of RAM.
    • There are two metal brackets holding each RAM stick in place. Carefully move the metal brackets outward on both sides at the same time.
    • Pull the RAM sticks out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hadi Termos
회원 가입일: 10/21/19
241 평판
안내서 2개를 작성함
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 UMass Dartmouth, Team S1-G2, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G2
4 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 935
