주요 콘텐츠로 건너뛰기
Toshiba Satellite P75-A7100 Fan Replacement
Pria Dalrymple
Pria Dalrymple2 다른 기여자
최종 수정일 June 12, 2018
10 - 15 분
조정
Through this guide you will learn to replace the fan inside of your laptop. Make sure you have the proper tools in order to complete the repair. This kind of repair is usually done to fix the problem of your laptop overheating.
필요한 것
도구
  1. Toshiba Satellite P75-A7100 Fan Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the tabs apart from each other.
  2. Toshiba Satellite P75-A7100 Fan Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Satellite P75-A7100 Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the battery upwards and remove it from the device.
  3. Toshiba Satellite P75-A7100 Fan Replacement, Wi-Fi Adapter: 3 단계, 이미지 2개 중 1개 Toshiba Satellite P75-A7100 Fan Replacement, Wi-Fi Adapter: 3 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the screw from the back cover.
    • Remove the back cover from the device.
  4. Toshiba Satellite P75-A7100 Fan Replacement: 4 단계, 이미지 3개 중 1개 Toshiba Satellite P75-A7100 Fan Replacement: 4 단계, 이미지 3개 중 2개 Toshiba Satellite P75-A7100 Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the optical drive from the device.
  5. Toshiba Satellite P75-A7100 Fan Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Satellite P75-A7100 Fan Replacement: 5 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop.
    • Remove the back cover from your device.
  6. Toshiba Satellite P75-A7100 Fan Replacement: 6 단계, 이미지 3개 중 1개 Toshiba Satellite P75-A7100 Fan Replacement: 6 단계, 이미지 3개 중 2개 Toshiba Satellite P75-A7100 Fan Replacement: 6 단계, 이미지 3개 중 3개
    • Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard.
    • Remove the Wi-Fi adapter from the device.
  7. Toshiba Satellite P75-A7100 Fan Replacement, Fan: 7 단계, 이미지 2개 중 1개 Toshiba Satellite P75-A7100 Fan Replacement, Fan: 7 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, unscrew the 6 remaining screws attached to the fan.
    • Unplug the connector connecting the fan to the motherboard.
    • Remove the fan from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Pria Dalrymple
회원 가입일: 01/17/18
144 평판
안내서 1개를 작성함
댓글 한 개
How do you remove and replace the fan from from/to the heatsink? Mine is secured with a metallic tape that is not sticky once removed.
Bruce - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 2,360
