주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toshiba Satellite P855-S5102 Keyboard Replacement
Benson Smith
Benson Smith다른 한 명의 기여자
최종 수정일 2018년 6월 26일
예상시간 없음
조정
The keyboard is the part of the computer that lets you enter data into it. If the keyboard is sticking or not functioning properly it will be hard to enter data. Below are a few steps on how to remove the keyboard.
필요한 것
도구
  1. Toshiba Satellite P855-S5102 Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 Toshiba Satellite P855-S5102 Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry up the keyboard cover.
  2. Toshiba Satellite P855-S5102 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Satellite P855-S5102 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry up the keyboard.
  3. Toshiba Satellite P855-S5102 Keyboard Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Satellite P855-S5102 Keyboard Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Satellite P855-S5102 Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Lay the keyboard upright against the screen.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Remove the ribbon cable from the socket.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
향후 수리를 위한 준비
모두 쇼핑하기
작성자
1다른 기여자 명과 함께
Benson Smith
회원 가입일: 01/25/18
351 평판
안내서 3개를 작성함
USF Tampa, Team S20-G3, Passmore Spring 2018 USF Tampa, Team S20-G3, Passmore Spring 2018 회원
USFT-PASSMORE-S18S20G3
4 회원들
안내서 7개를 작성함
1가이드 댓글
Proceeding this way you will get to break all seals that join that “cover“ to the rest of the keyboard assembly, rendering it unusable if you were not replacing it (in the “step 2“ photos you get to see all the broken pins where the joined parts used to be). In fact, you have to proceed from the other side and remove the cover from under the computer, there you’ll find some small tabs towards the touchpad end of things, you gently pry each tab while loosening that side of the keyboard and it rises up. Be careful not to break the flex circuit that joins it to the mainboard in the process.
Kenneth - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 570
