Toshiba Tecra 8200 Hard Drive Replacement
5 분
쉬움
If your Toshiba Tecra 8200 is running slowly or you are unable to save documents, your hard drive may need replacement.
Locate the hard drive panel.
Remove the single screw labeled F4 by using a Philips size #00 screwdriver.
Save the screw, as it will be needed for reassembly.
Remove the panel, exposing the hard drive.
거의 끝나갑니다!
결승점
