주요 콘텐츠로 건너뛰기
Trek 800 Bicycle Rear Tire Bike Tube Replacement
Ryen Simpson
Ryen Simpson9 다른 기여자
최종 수정일 December 22, 2021
10 - 20 분
쉬움
There are many reasons why a bicycle tire may become flat. Often it is caused by running over debris or pumping up the tires too much. Punctures can create small holes that can cause slow leaks whereas tires pumped up too much will cause the inner tube to burst. When anything like this occurs, the inner tube needs to be replaced. This guide will demonstrate the process required to fix a worn or punctured bike tube on a Trek 800 model bicycle with no prior experience. After finishing, your bicycle will be ready to ride!
  1. Trek 800 Bicycle Rear Tire Bike Tube Replacement, Rear Tire Bike Tube: 1 단계, 이미지 1개 중 1개
    • Acknowledge that you have a flat tire.
    • Signs of a flat tire: deflated without rider. If the tire looks inflated, but deflates when sitting on the bicycle, it is not inflated enough. In general, the pressure should be at the maximum recommendation on the sidewall of the tire (less wear and drag, and reduces risk of puncture).
  2. Trek 800 Bicycle Rear Tire Bike Tube Replacement: 2 단계, 이미지 1개 중 1개
    • Note the size of tube needed and optimum tire pressure.
    • It is best to know this prior to purchasing a bicycle tube, as well as inflating the tube to the proper maximum pressure in the last step.
  3. Trek 800 Bicycle Rear Tire Bike Tube Replacement: 3 단계, 이미지 3개 중 1개 Trek 800 Bicycle Rear Tire Bike Tube Replacement: 3 단계, 이미지 3개 중 2개 Trek 800 Bicycle Rear Tire Bike Tube Replacement: 3 단계, 이미지 3개 중 3개
    • Disengage the rear brake before you remove the rear wheel.
    • Pinch the arms to compress the brake cable.
    • Pull the cable out of the lever and it will fully release.
    • If your brake does not have a quick release (as shown in the picture) you may have to loosen the nut securing the brake cable to open the brakes.
  4. Trek 800 Bicycle Rear Tire Bike Tube Replacement: 4 단계, 이미지 2개 중 1개 Trek 800 Bicycle Rear Tire Bike Tube Replacement: 4 단계, 이미지 2개 중 2개
    • Locate the skewer on the center of the wheel attached to the bicycle frame slots.
    • Turn the skewer lever away from the bicycle.
    • Turn the skewer cap counter clockwise.
    • Once it is loose enough, you can pull the tire off, but do not pull it yet entirely off.
    • If your bike does not have a quick release for the wheel, you will need to unscrew the axle nut.
    • Some anti-theft gravity nuts require the bike to be upside down, others need a special wrench. However, you'll know if you have bought such an anti-theft device.
  5. Trek 800 Bicycle Rear Tire Bike Tube Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the chain from the sprocket.
    • The chain will usually be covered in grease or rust. Wear gloves or use a rag to avoid getting dirty when moving the chain.
  6. Trek 800 Bicycle Rear Tire Bike Tube Replacement: 6 단계, 이미지 2개 중 1개 Trek 800 Bicycle Rear Tire Bike Tube Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the tire and the rim off of the bike.
    • Pinch the tire and separate from the rim.
    • A plastic tire lever can be useful.
  7. Trek 800 Bicycle Rear Tire Bike Tube Replacement: 7 단계, 이미지 1개 중 1개
  8. Trek 800 Bicycle Rear Tire Bike Tube Replacement: 8 단계, 이미지 3개 중 1개 Trek 800 Bicycle Rear Tire Bike Tube Replacement: 8 단계, 이미지 3개 중 2개 Trek 800 Bicycle Rear Tire Bike Tube Replacement: 8 단계, 이미지 3개 중 3개
    • Put the tire with the new tube inside back on the rim.
    • Inflate the tube slightly to make it easier to insert inside the tire prior to attatching the tire and tube combo back on the rim.
    • Make sure the hole in the rim lines up with the valve on the tube properly.
    • Avoid a misaligned valve. This can cause the valve to break internally as the rubber will be cut around the valve stem by the wheel where the valve protrudes from the rim.
  9. Trek 800 Bicycle Rear Tire Bike Tube Replacement: 9 단계, 이미지 3개 중 1개 Trek 800 Bicycle Rear Tire Bike Tube Replacement: 9 단계, 이미지 3개 중 2개 Trek 800 Bicycle Rear Tire Bike Tube Replacement: 9 단계, 이미지 3개 중 3개
    • Re-attach the rim to the bike frame in reverse order of removal.
    • Make sure the chain aligns with the sprocket.
    • Slide the quick-release skewer into the slots in the bike frame.
  10. Trek 800 Bicycle Rear Tire Bike Tube Replacement: 10 단계, 이미지 3개 중 1개 Trek 800 Bicycle Rear Tire Bike Tube Replacement: 10 단계, 이미지 3개 중 2개 Trek 800 Bicycle Rear Tire Bike Tube Replacement: 10 단계, 이미지 3개 중 3개
    • Make sure the skewer is completely inserted into the frame slots before tightening.
    • Rotate the skewer cap clockwise and ensure a snug contact between the skewer caps and the frame slots.
    • Rotate the skewer lever towards the bicycle frame.
    • If the skewer lever is too difficult to twist towards the frame, back off the skewer cap until you can twist the lever towards the bicycle frame and it feels snug.
  11. Trek 800 Bicycle Rear Tire Bike Tube Replacement: 11 단계, 이미지 2개 중 1개 Trek 800 Bicycle Rear Tire Bike Tube Replacement: 11 단계, 이미지 2개 중 2개
    • Re-attach the rear brake.
    • Reference step 3 in reverse order.
  12. Trek 800 Bicycle Rear Tire Bike Tube Replacement: 12 단계, 이미지 3개 중 1개 Trek 800 Bicycle Rear Tire Bike Tube Replacement: 12 단계, 이미지 3개 중 2개 Trek 800 Bicycle Rear Tire Bike Tube Replacement: 12 단계, 이미지 3개 중 3개
    • Inflate the tube to the specified pressure on tire sidewall (refer to step 2).
    • Insert the tire pump head into the valve, and lock with lever on the pump head.
    • This tire is inflated to a maximum pressure of 40 psi.
결론
If all of your steps were completed correctly you should be free to ride. Enjoy.
작성자
9다른 기여자 명과 함께
Ryen Simpson
회원 가입일: 02/24/15
137 평판
안내서 1개를 작성함
Cal Poly, Team 23-2, Green Winter 2015 Cal Poly, Team 23-2, Green Winter 2015 회원
CPSU-GREEN-W15S23G2
4 회원들
안내서 18개를 작성함
댓글 한 개
Thanks for providing these instructions. But I think the most difficult step (getting the tire off the rim) should be explained in more detail.
Nils Faltin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 24
전체 시간: 3,580
