주요 콘텐츠로 건너뛰기
Trek 820 Light Mount Replacement
Kaveh Karimiyanha
Kaveh Karimiyanha6 다른 기여자
최종 수정일 December 13, 2018
5 분
쉬움
더 나은 이미지가 필요함
You may need to replace the light mount on your bicycle because the light has burned out or you require a brighter light. This guide shows the proper steps to install a replacement Light Mount for a Trek 820 (or similar) bicycle. No tools are necessary for this easy repair.
필요한 것
  1. Trek 820 Light Mount Replacement, Light Mount: 1 단계, 이미지 2개 중 1개 Trek 820 Light Mount Replacement, Light Mount: 1 단계, 이미지 2개 중 2개
    • Clean the area where the light mount will be installed with a soft cloth.
    • Placing the light mount close to the center stem.
  2. Trek 820 Light Mount Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the strap from the light mount fitting.
    • Stretch the strap clockwise around the handlebars.
  3. Trek 820 Light Mount Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the strap through the slot and fasten to a snug, but moveable fit.
    • Do not fasten too tight as this will make it difficult to fine tune light mount placement.
  4. Trek 820 Light Mount Replacement: 4 단계, 이미지 1개 중 1개
    • Pull the strap tightly through the clasps at the bottom of the mount.
  5. Trek 820 Light Mount Replacement: 5 단계, 이미지 2개 중 1개 Trek 820 Light Mount Replacement: 5 단계, 이미지 2개 중 2개
    • Place the fastening screw in the rear screw port on the light mount.
    • Twist the screw clockwise using your hands until fully fastened.
결론
Now you have a light mount ready for safer night rides on your Trek bicycle!
작성자
6다른 기여자 명과 함께
Kaveh Karimiyanha
회원 가입일: 09/24/12
813 평판
안내서 7개를 작성함
Cal Poly, Team 1-1, Propen Fall 2012 Cal Poly, Team 1-1, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G1
5 회원들
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 870
