주요 콘텐츠로 건너뛰기
Triace A310 Brake Cable Replacement
Ben Hartinger
Ben Hartinger6 다른 기여자
최종 수정일 September 4, 2019
15 분
쉬움
This guide will show you how to replace an old or damaged brake cable. If you need to swap out your brake cable, this will help you replace it safely.
필요한 것
도구
  1. Triace A310 Brake Cable Replacement, Brake Cable: 1 단계, 이미지 2개 중 1개 Triace A310 Brake Cable Replacement, Brake Cable: 1 단계, 이미지 2개 중 2개
    • WARNING: Be sure to follow each step carefully. Failure to do so may result in serious injury or death.
    • Unscrew the screw holding the brake cable in place with a 5mm allen wrench and pull out the cable.
  2. Triace A310 Brake Cable Replacement: 2 단계, 이미지 3개 중 1개 Triace A310 Brake Cable Replacement: 2 단계, 이미지 3개 중 2개 Triace A310 Brake Cable Replacement: 2 단계, 이미지 3개 중 3개
    • Unscrew the slotted brake cable cap on the rear tire and pull out the cable. Remove the cap from the cable.
  3. Triace A310 Brake Cable Replacement: 3 단계, 이미지 2개 중 1개 Triace A310 Brake Cable Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew the cap next to the brake handle and remove it from the cable.
  4. Triace A310 Brake Cable Replacement: 4 단계, 이미지 3개 중 1개 Triace A310 Brake Cable Replacement: 4 단계, 이미지 3개 중 2개 Triace A310 Brake Cable Replacement: 4 단계, 이미지 3개 중 3개
    • Pull up and out on the cable to remove the barrel nipple (the small cylinder at the end of the cable).
  5. Triace A310 Brake Cable Replacement: 5 단계, 이미지 3개 중 1개 Triace A310 Brake Cable Replacement: 5 단계, 이미지 3개 중 2개 Triace A310 Brake Cable Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the bracket located on the front tire with a 3mm allen wrench.
    • Rotate the bracket 90 degrees or until the opening is large enough for the cable. Remove the cable.
    • Note that if removing cable for rear brake, rather than unscrewing a bracket, you will unclip several "spring" clips. Keep track of clips.
    • Test your brakes in a low-speed environment to ensure that they work.
결론
To place the new cable, follow these instructions in reverse order.
작성자
6다른 기여자 명과 함께
Ben Hartinger
회원 가입일: 01/27/14
340 평판
안내서 3개를 작성함
Cal Poly, Team 1-37, Maness Winter 2014 Cal Poly, Team 1-37, Maness Winter 2014 회원
CPSU-MANESS-W14S1G37
4 회원들
안내서 11개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 4
전체 시간: 353
