주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Triace A310 Chain Replacement
필요한 것
    1. Triace A310 Chain Replacement, Tire: 1 단계, 이미지 1개 중 1개
      • Begin loosening the tire by turning the quick release handle.
      댓글 쓰기
    2. Triace A310 Chain Replacement: 2 단계, 이미지 2개 중 1개 Triace A310 Chain Replacement: 2 단계, 이미지 2개 중 2개
      • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
      • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
      댓글 쓰기
    3. Triace A310 Chain Replacement: 3 단계, 이미지 2개 중 1개 Triace A310 Chain Replacement: 3 단계, 이미지 2개 중 2개
      • There should be enough slack, in the chain, at this point to remove the tire from the bike.
      • Note: You may need to wiggle the tire and chain around in order to create enough slack.
      • Remove the tire from the bike.
      댓글 쓰기
    1. Triace A310 Chain Replacement, Chain: 4 단계, 이미지 3개 중 1개 Triace A310 Chain Replacement, Chain: 4 단계, 이미지 3개 중 2개 Triace A310 Chain Replacement, Chain: 4 단계, 이미지 3개 중 3개
      • Locate the master link along the chain.
      • Note: If the master link matches the one pictured in this step continue with the instructions, if not skip to the next step.
      • With pliers squeeze the two pins together so that the chain comes apart.
      댓글 쓰기
    2. Triace A310 Chain Replacement: 5 단계, 이미지 3개 중 1개 Triace A310 Chain Replacement: 5 단계, 이미지 3개 중 2개 Triace A310 Chain Replacement: 5 단계, 이미지 3개 중 3개
      • Note: This step is only for chains with a master link clip.
      • With a plier press the two pins together and remove the clip.
      • Once the clip is removed the chain should easily come apart.
      댓글 쓰기
    3. Triace A310 Chain Replacement: 6 단계, 이미지 1개 중 1개
      • Once the chain is separated, remove it from the bike by pulling one end.
      댓글 쓰기
    4. Triace A310 Chain Replacement: 7 단계, 이미지 3개 중 1개 Triace A310 Chain Replacement: 7 단계, 이미지 3개 중 2개 Triace A310 Chain Replacement: 7 단계, 이미지 3개 중 3개
      • With the new chain, place it on the current gear that your bike is in.
      • Note: If you don't know which gear your bike is in place the chain on one of the middle gears.
      • Thread one end of the chain through the derailleur from top to bottom so it is in the shape of a 'S'.
      • Next place the chain on the back gears, making sure that it is threaded through the guide.
      댓글 쓰기
    5. Triace A310 Chain Replacement: 8 단계, 이미지 3개 중 1개 Triace A310 Chain Replacement: 8 단계, 이미지 3개 중 2개 Triace A310 Chain Replacement: 8 단계, 이미지 3개 중 3개
      • To reassemble the chain bring both ends of the chain together so that the pins on each one lineup.
      • Grip the chain on both sides of the master link and pull.
      댓글 쓰기
    6. Triace A310 Chain Replacement: 9 단계, 이미지 3개 중 1개 Triace A310 Chain Replacement: 9 단계, 이미지 3개 중 2개 Triace A310 Chain Replacement: 9 단계, 이미지 3개 중 3개
      • If your chain does have a master link clip replace the link around the two pins.
      • Use a plier to slide the clip back into place.
      댓글 쓰기
결론
Once your chain is back together, you are ready to once again, hit the trails.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jacob Rickman
회원 가입일: 01/26/14
159 평판
안내서 1개를 작성함
Cal Poly, Team 1-37, Maness Winter 2014 Cal Poly, Team 1-37, Maness Winter 2014 회원
CPSU-MANESS-W14S1G37
4 회원들
안내서 71개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 11
지난 30일: 29
전체 시간: 1,201
