주요 콘텐츠로 건너뛰기
Turtle Beach Elite Pro Ear Cushions Replacement
Alexis Uribe
Alexis Uribe2 다른 기여자
최종 수정일 June 30, 2022
5 분
쉬움
The guide will assist users with replacing damaged ear cushions. It will show users how to replace a torn or worn out ear cushion with a new one.
  1. Turtle Beach Elite Pro Ear Cushions Replacement, Ear Cushions: 1 단계, 이미지 1개 중 1개
    • Firmly pinch ear cushion between thumb and forefinger.
    • Using the hand not holding the ear cushion, grasp the orange plate that is below the ear cushion.
    • If the black rubber lining on the orange plate is grasped, then the rubber lining on the ear piece may tear.
  2. Turtle Beach Elite Pro Ear Cushions Replacement: 2 단계, 이미지 2개 중 1개 Turtle Beach Elite Pro Ear Cushions Replacement: 2 단계, 이미지 2개 중 2개
    • Rotate ear cushion counter-clockwise about half an inch.
    • The ear cushion should audibly snap out of place.
    • After it has audibly snapped out of place, lift the ear cushion off of the device.
    • During reassembly, rotate the ear cushion clockwise.
  3. Turtle Beach Elite Pro Ear Cushions Replacement: 3 단계, 이미지 2개 중 1개 Turtle Beach Elite Pro Ear Cushions Replacement: 3 단계, 이미지 2개 중 2개
    • Using the new cushion, align the pegs located on both the orange plate and ear cushion.
    • Make sure that both the ear cushion and the orange plate have the same designation.
    • Once the pegs are aligned, push the new ear cushion in place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alexis Uribe
회원 가입일: 03/24/17
510 평판
안내서 4개를 작성함
Baylor, Team S5-G1, Williams Spring 2017 Baylor, Team S5-G1, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G1
3 회원들
안내서 8개를 작성함
댓글 한 개
Any recommendations as to where you can get replacements please?
John Gallacher - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 35
전체 시간: 2,879
