주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Turtle Beach PX22 Microphone Replacement
필요한 것
    1. Turtle Beach PX22 Microphone Replacement, Microphone: 1 단계, 이미지 3개 중 1개 Turtle Beach PX22 Microphone Replacement, Microphone: 1 단계, 이미지 3개 중 2개 Turtle Beach PX22 Microphone Replacement, Microphone: 1 단계, 이미지 3개 중 3개
      • Use your fingers to peel off ear cushion by pinching and pulling off the leather.
      • Use a Philips #00 head screwdriver to remove three 7.1 mm screws around the speaker.
      • The housing will come loose.
      • Gently lift the speaker housing off the ear cup, being careful not to pull on the driver/speaker assembly, which is still connected to a board inside.
      댓글 쓰기
    2. Turtle Beach PX22 Microphone Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the 7.1 mm screw with a Phillips #2 screwdriver to gain access to the microphone.
      • You may need to pull the wire with the knot out of the way of the screw.
      댓글 쓰기
    3. Turtle Beach PX22 Microphone Replacement: 3 단계, 이미지 1개 중 1개
      • Use a soldering iron to carefully desolder the microphone wire connectors from the board.
      • Take care not to overheat the board or nearby components.
      • Insert the new microphone and solder the wires into the correct positions.
      • Replace the screw that secures the microphone with a Phillips #2 screwdriver.
      • Pull the excess microphone wire back into the speaker housing.
      • Hold the microphone neck so that it does not rotate when screwing.
      댓글 쓰기
    4. Turtle Beach PX22 Microphone Replacement: 4 단계, 이미지 3개 중 1개 Turtle Beach PX22 Microphone Replacement: 4 단계, 이미지 3개 중 2개 Turtle Beach PX22 Microphone Replacement: 4 단계, 이미지 3개 중 3개
      • Position the speaker on the headset so that the screw holes line up. It should click into place.
      • Use a Phillips #00 screwdriver to secure the three screws.
      • Replace the ear cushion.
      • Use the plastic opening tool to tuck excess leather inside the headset.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
James de Iturrondo
회원 가입일: 03/18/15
709 평판
안내서 4개를 작성함
UMass Dartmouth, Team 3-1, Duarte Spring 2015 UMass Dartmouth, Team 3-1, Duarte Spring 2015 회원
UMASSD-DUARTE-S15S3G1
4 회원들
안내서 16개를 작성함
3가이드 댓글
Where do we buy the mic?
Brit B - 답글 공유
could someone help me say what each and every on of those wire points on this logic board goes to? like 1,2,3,4,5 and 6, what do they go to???
alexalv55 - 답글 공유
i need the cable for my px 24 it broke in my phone how do i get a new cable to fix my px 24 headset
rjbubba1960 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 37
전체 시간: 7,339
