주요 콘텐츠로 건너뛰기
Uninstalling an Electric Water Heater
Lindsay Martin
Lindsay Martin7 다른 기여자
최종 수정일 June 9, 2022
1 - 2 시간
조정
This guide will show you how to safely disconnect an electric water heater from power, drain any remaining water, and remove the appliance for replacement.
An electric water heater is a tank that heats water using high-voltage electric rods that run through the tank. Water is heated starting at the center of the tank and radiates outward. These heaters can range in size from two to 50 gallons.
An electric water heater may need be to be replaced when you notice decreased performance and/or it is nearing the end of its lifespan (about 10-15 years). Before starting this project, learn whether your electric water heater needs to be repaired or replaced. It is also important to find out how to safely get rid of your old water heater.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Uninstalling an Electric Water Heater, Water Heater: 1 단계, 이미지 1개 중 1개
    • At the breaker box, locate the breaker for the water heater. Switch the breaker bar to the off position.
    • Using a multimeter, check the line voltage at the water heater. The multimeter should read "0 VAC."
  2. Uninstalling an Electric Water Heater: 2 단계, 이미지 2개 중 1개 Uninstalling an Electric Water Heater: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #0 screwdriver, remove the access panel (or panels) to access the thermostat and element.
    • Some electric water heater models may have only one access panel, located near the bottom of the tank. Some may have two— both an upper and lower access panel.
    • Set aside the access panel cover and screws. Remove the insulation to expose the wires, thermostat, and element.
    • Disconnect the wiring from the electrical components in the panel.
  3. Uninstalling an Electric Water Heater, Draining the tank: 4 단계, 이미지 1개 중 1개
    • Attach a hose to the drain valve located at the bottom of the tank, near the lower access panel. Place the other end of the hose in a safe location for the water to drain.
    • Open the drain valve on the water heater by turning it counter-clockwise.
    • Once you have a steady flow of water coming out of the hose, slowly close the cold water valve to the water heater by turning it clockwise.
    • If the water flow slows down, you can open a sink or tub faucet to help the tank drain quicker.
  4. Uninstalling an Electric Water Heater: 5 단계, 이미지 1개 중 1개
    • Using adjustable pliers, disconnect the water lines from the tank.
    • If the lines are glued in place, you will need to use a steel wire saw to disconnect the water line.
  5. Uninstalling an Electric Water Heater: 6 단계, 이미지 2개 중 1개 Uninstalling an Electric Water Heater: 6 단계, 이미지 2개 중 2개
    • Using a pipe wrench, detach all remaining pipes from the tank.
  6. Uninstalling an Electric Water Heater: 7 단계, 이미지 1개 중 1개
    • Remove the water tank.
    • The tank will have sediment and some water in it. It will be heavy and require at least 2 people to move it safely.
    • To install a new water heater, follow the manufacturer's installation instructions included with the new appliance.
결론
To install a new water heater, follow the manufacturer’s installation instructions provided with the new water heater.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Lindsay Martin
회원 가입일: 09/20/17
178 평판
안내서 1개를 작성함
댓글 한 개
If you have enough assistance to transport the unit outside the house, taking apart an old water heater is simple. Components, mounting hardware, and other aspects of a water heater can all be removed independently. Nonetheless, it takes strength to pull the old water from its place and move it outside for proper disposal.
Juliet Cyrus - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 38
지난 30일: 81
전체 시간: 5,530
