주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VTech Baby's Learning Laptop LEDs Replacement
필요한 것
    1. VTech Baby's Learning Laptop LEDs Replacement, LEDs: 1 단계, 이미지 1개 중 1개
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      댓글 쓰기
    2. VTech Baby's Learning Laptop LEDs Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the battery door.
      • Take out the batteries.
      댓글 쓰기
    3. VTech Baby's Learning Laptop LEDs Replacement: 3 단계, 이미지 2개 중 1개 VTech Baby's Learning Laptop LEDs Replacement: 3 단계, 이미지 2개 중 2개
      • Using a Phillips #0 screwdriver, unscrew the six 7.3mm screws holding the screen together.
      댓글 쓰기
    4. VTech Baby's Learning Laptop LEDs Replacement: 4 단계, 이미지 3개 중 1개 VTech Baby's Learning Laptop LEDs Replacement: 4 단계, 이미지 3개 중 2개 VTech Baby's Learning Laptop LEDs Replacement: 4 단계, 이미지 3개 중 3개
      • With the lid closed, position the device such that the handle is pointing towards you.
      • Using your fingers, gently pry open the cover from the hinge.
      • Attempting to remove the cover while the lid is still open may cause unwanted damage to the device.
      댓글 쓰기
    5. VTech Baby's Learning Laptop LEDs Replacement: 5 단계, 이미지 1개 중 1개
      • Remove two 6.0mm screws from the LED array using a Phillips #0 screwdriver.
      댓글 쓰기
    6. VTech Baby's Learning Laptop LEDs Replacement: 6 단계, 이미지 1개 중 1개
      • Pickup the array by the opening in the center of the board.
      • Remove the faulty LEDs by desoldering each from the board. You may refer to this soldering guide if necessary.
      • Movement of the array will be limited as it is still attached to the main device board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Christopher Kourmoulakis
회원 가입일: 09/03/15
412 평판
안내서 3개를 작성함
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G2
4 회원들
안내서 57개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 35
전체 시간: 1,580
