주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VTech InnoTab 2 Headphone Jack Replacement
필요한 것
    1. VTech InnoTab 2 Headphone Jack Replacement, Battery: 1 단계, 이미지 3개 중 1개 VTech InnoTab 2 Headphone Jack Replacement, Battery: 1 단계, 이미지 3개 중 2개 VTech InnoTab 2 Headphone Jack Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Apply slight pressure and slide the button above the battery cabinet to the right to open.
      • Remove battery cabinet cover by sliding away from the center of device.
      • This device requires 4AA batteries to function without the AC adaptor.
      댓글 쓰기
    1. VTech InnoTab 2 Headphone Jack Replacement, Back Panel: 2 단계, 이미지 3개 중 1개 VTech InnoTab 2 Headphone Jack Replacement, Back Panel: 2 단계, 이미지 3개 중 2개 VTech InnoTab 2 Headphone Jack Replacement, Back Panel: 2 단계, 이미지 3개 중 3개
      • Remove all nine plastic caps from the back of the device using the plastic opening tool.
      • These covers are made of hard plastic so they may be difficult to remove.
      댓글 쓰기
    2. VTech InnoTab 2 Headphone Jack Replacement: 3 단계, 이미지 3개 중 1개 VTech InnoTab 2 Headphone Jack Replacement: 3 단계, 이미지 3개 중 2개 VTech InnoTab 2 Headphone Jack Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
      • Be careful not to apply excessive force.
      • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
      댓글 쓰기
    3. VTech InnoTab 2 Headphone Jack Replacement: 4 단계, 이미지 2개 중 1개 VTech InnoTab 2 Headphone Jack Replacement: 4 단계, 이미지 2개 중 2개
      • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
      • Do not use excessive force while removing the screws to prevent damaging the plastic case.
      댓글 쓰기
    4. VTech InnoTab 2 Headphone Jack Replacement: 5 단계, 이미지 2개 중 1개 VTech InnoTab 2 Headphone Jack Replacement: 5 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, detach the back plate from the front piece.
      • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
      • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
      댓글 쓰기
    1. VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: 6 단계, 이미지 3개 중 1개 VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: 6 단계, 이미지 3개 중 2개 VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: 6 단계, 이미지 3개 중 3개
      • Remove the two 7 mm screws from the left bumper of the device using a JO screwdriver.
      • Be careful not to pull to hard when removing the bumper to avoid damage to the circuit.
      댓글 쓰기
    2. VTech InnoTab 2 Headphone Jack Replacement: 7 단계, 이미지 3개 중 1개 VTech InnoTab 2 Headphone Jack Replacement: 7 단계, 이미지 3개 중 2개 VTech InnoTab 2 Headphone Jack Replacement: 7 단계, 이미지 3개 중 3개
      • Use your fingers to gently remove the headphone jack.
      • De-solder the points shown to fully remove the headphone jack from the motherboard.
      • A soldering guide offered by IFIXIT can be found here Soldering Skills
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Roberto Valdes
회원 가입일: 10/18/17
302 평판
안내서 3개를 작성함
USF Tampa, Team S1-G85, Cagle Fall 2017 USF Tampa, Team S1-G85, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G85
2 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 24
전체 시간: 530
