VTech Kidizoom Smartwatch DX2 Faceplate Replacement
If the faceplate to your watch is cracked or simply needs a clean, the following guide will show how to remove and replace this piece.
필요한 것
In order to remove the faceplate you must start by placing the watch screen upwards.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 4개
Where can I find a faceplate?
This doesn't remove the faceplate, just the decorative bezel around the screen. I'm looking for disassembly instructions to open up the screen as my son wore his I to the pool (immediately after being told not to! Kids…)
Where can I get a replacement faceplate please
