주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VTech Little Apps Tablet Speaker Replacement
필요한 것
    1. VTech Little Apps Tablet Speaker Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
      댓글 쓰기
    2. VTech Little Apps Tablet Speaker Replacement: 2 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to pry the batteries out of their holding.
      • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
      댓글 쓰기
    1. VTech Little Apps Tablet Speaker Replacement, Back Cover: 3 단계, 이미지 2개 중 1개 VTech Little Apps Tablet Speaker Replacement, Back Cover: 3 단계, 이미지 2개 중 2개
      • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
      • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
      댓글 쓰기
    2. VTech Little Apps Tablet Speaker Replacement: 4 단계, 이미지 2개 중 1개 VTech Little Apps Tablet Speaker Replacement: 4 단계, 이미지 2개 중 2개
      • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
      • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
      댓글 쓰기
    1. VTech Little Apps Tablet Speaker Replacement, Speaker: 5 단계, 이미지 2개 중 1개 VTech Little Apps Tablet Speaker Replacement, Speaker: 5 단계, 이미지 2개 중 2개
      • The speaker should be located at the bottom-right side of the back cover from your perspective.
      • Remove the two 7.3 mm panhead screws holding down the speaker with a PH0 driver head.
      • Be careful not to disturb the wires while removing the screws.
      댓글 쓰기
    2. VTech Little Apps Tablet Speaker Replacement: 6 단계, 이미지 2개 중 1개 VTech Little Apps Tablet Speaker Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the speaker from its holding and place it to the side of the device.
      • Desolder the brown wires from the speaker connections.
      • Soldering is the most difficult step in this guide. If you are in need of assistance with this step, refer to this Soldering Guide.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Johnnie Cairns
회원 가입일: 02/10/16
522 평판
안내서 4개를 작성함
USF Tampa, Team 2-6, Sullivan Spring 2016 USF Tampa, Team 2-6, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G6
3 회원들
안내서 42개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 41
전체 시간: 1,609
