주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Verizon Ellipsis 8 Disassembly
필요한 것
    1. Verizon Ellipsis 8 Disassembly, Power Down and Remove Sim Card: 1 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Open SIM card flap and remove SIM card. Use a pair of tweezers to get the SIM card out.
      댓글 쓰기
    2. Verizon Ellipsis 8 Disassembly, Remove Rear Cover: 2 단계, 이미지 1개 중 1개
      • Use a guitar pick to open the cover of the tablet. For most effective results, start at the corner of the tablet and continue.
      • **BE SURE NOT TO DAMAGE THE SIM CARD OR SD CARD SLOTS**
      댓글 쓰기
    3. Verizon Ellipsis 8 Disassembly, Rear Cover Removal Cont.: 3 단계, 이미지 2개 중 1개 Verizon Ellipsis 8 Disassembly, Rear Cover Removal Cont.: 3 단계, 이미지 2개 중 2개
      • Continue opening the cover now using a metal spudger and wiggle it to pry the cover open.
      • You can look at the picture of the rear cover to see where the snaps are located.
      댓글 쓰기
    4. Verizon Ellipsis 8 Disassembly, Remove Battery: 4 단계, 이미지 1개 중 1개
      • Remove the screws attached to the circuit board on the battery using a Phillips 00 screw head and remove the battery.
      • There was no adhesive on the back of the battery, just along the sides.
      댓글 쓰기
    5. Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: 5 단계, 이미지 3개 중 1개 Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: 5 단계, 이미지 3개 중 2개 Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: 5 단계, 이미지 3개 중 3개
      • Be careful when removing the ribbon cables as there is adhesive on the back of them. To remove the cables flip up the rear part of the connector to slide the cable out - *gently*.
      • The USB Charging Connector and the Antenna Board both have adhesive on the back. Remove the screws and carefully lift up on the boards to remove them.
      • **Be careful with the antenna cable!**
      댓글 쓰기
    6. Verizon Ellipsis 8 Disassembly, Remove Mainboard & Speaker: 6 단계, 이미지 1개 중 1개
      • Remove the 5 screws holding the Mainboard and Speakers in to place. *One of the screws is under the ribbon cable*
      • There was no adhesive holding this board in and the whole assembly lifted out as one piece.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 31명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
SMcC21985
회원 가입일: 11/10/15
1,271 평판
안내서 2개를 작성함
4가이드 댓글
Keith Brockley - 답글 공유
what size screws are thoze i need to get some i lost some
stacy - 답글 공유
My tablet is on, when I press to Open , it doesn't do anything
Gladys Lockhart - 답글 공유
My tablet is on working, when I press to get is frozen, it doesn't let me in
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 60
전체 시간: 21,381
