주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Visual Land Prestige Pro 7D Battery Replacement
필요한 것
    1. Visual Land Prestige Pro 7D Battery Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
      댓글 쓰기
    2. Visual Land Prestige Pro 7D Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
      • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
      • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
      • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
      댓글 쓰기
    1. Visual Land Prestige Pro 7D Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
      • Pry a thin tool under the battery.
      • Be gentle and try not to bend the battery.
      • Slide the tool around all sides of the battery. Separate it evenly on all sides for the best result.
      댓글 쓰기
    2. Visual Land Prestige Pro 7D Battery Replacement: 4 단계, 이미지 2개 중 1개 Visual Land Prestige Pro 7D Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Soldering guns are hot and can easily damage the device.
      • Desolder the two connections between the red and blue wires where the battery connects to the circuit board.Soldering guns are hot and can easily damage the device.
      • For soldering information, see our guide: 연결부 납땜 및 납제거 방법.
      • If you are removing the LCD display this step is unnecessary.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Max Hudson
회원 가입일: 10/14/14
422 평판
안내서 2개를 작성함
Cal Poly, Team 10-41, Amido Fall 2014 Cal Poly, Team 10-41, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G41
4 회원들
안내서 42개를 작성함
1가이드 댓글
My tablet shows the icon battery What that mean
paularslay - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 33
전체 시간: 6,454
